    SD memory card is slowly filling up
    12 Posts 2 Posters 3.8k Views 2 Watching
    • D
      drx1984
      Hello everybody,
      can someone help me?
      My MagicMirror runs for almost a year without errors, but slowly the SD memory card (32GB) is filling up by itself?
      After my MagicMirror installation I had about 24GB of free space. And now I only have 6.1GB free (see picture).
      What do I have to do to get burst again?
      thank you
        sdetweil @drx1984
        @drx1984 there are utilities which can tell u space used
        see the first command described here
        https://www.tecmint.com/find-top-large-directories-and-files-sizes-in-linux/amp/
        • D
          drx1984
          it looks like this
            sdetweil @drx1984
            @drx1984 clear the logs. pm2 flush
            altho I might want to find out what all that is.
            u can dump a little
            pm2 logs --lines=???
            ???= some number, default is 15
            u can also.look at them in the ~/.pm2/logs
            folder
            D 1 Reply Last reply
            • D
              drx1984
              how do I do that? (I’m a beginner sry)
              can I turn off the log?
              how do i get to the pm2 folder? that should be in the “root” folder right? somehow I have no notice.
              • D
                drx1984 @sdetweil
                I was able to do something and I found this post:
                https://forum.magicmirror.builders/topic/917/pm2-logs/7
                I then entered the command “pm2 flush” and I already have 21GB of free space again, that looks very good.
                could I automate something like that? or deactivate the pm2 log?
                  sdetweil @drx1984
                  @drx1984 I gave u the pm2 flush command
                  if u install winscp on your pc box, and enable ssh on your pi, you can get a file manager.over the pi files from your pc
                  then just double click to edit like u do on the pc. right click to rename/delete
                  I would have looked at the log to find out what modules are generating all that content.
                  far as I know there is no way to turn off the log.
                  maybe
                  pm2 help
                  would some some options
                    @drx1984
                    also file location
                    means users home folder
                    so when logged on as pi, that means
                    /home/pi
                    so from my post
                    ~/.pm2/logs means
                    /home/pi/.pm2/logs
                    u can get there over ssh, or using a terminal window on the pi, or a file manager on the pi, just like u do on widows
                    • D
                      drx1984 @sdetweil
                      yes I had already installed the program WinSCP, but I don’t see this folder pm2 ??? ( see image)
                      Yes that would be interesting which modules cause these logs. next time I won’t just delete it.
                      • D
                        drx1984 @drx1984
                        @drx1984 said in SD memory card is slowly filling up:
                        ah it was hidden all clear, thank you
                        • D
                          drx1984 @drx1984
                          I saw that there is a tool for deleting the pm2 log, do you know it: https://github.com/keymetrics/pm2-logrotate
                            sdetweil @drx1984
                            @drx1984 no. but looks interesting
                            as for hidden, for others, see
                            https://winscp.net/forum/viewtopic.php?t=24963
