    Failed to install dependencies, while trying to install MM2
    10 Posts 3 Posters 1.1k Views 2 Watching
    • M
      MaikH1
      I tried different methods of installing MM, still without succes.
      See below the response i’m getting
      pi@raspberry:~ $ npm install
      /usr/local/lib/node_modules/npm/bin/npm-cli.js:87
      let notifier = require(‘update-notifier’)({pkg})
      SyntaxError: Unexpected identifier
      at Module._compile (module.js:439:25)
      at Object.Module._extensions…js (module.js:474:10)
      at Module.load (module.js:356:32)
      at Function.Module._load (module.js:312:12)
      at Function.Module.runMain (module.js:497:10)
      at startup (node.js:119:16)
      at node.js:906:3
      Anyone any id what to do?
      Re: Failed to install dependencies RPI3 B+
      • swvalentiS
        swvalenti Project Sponsor
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        Delete MM folder or rename it and run this install script from @sdetweil
          sdetweil @MaikH1
          @MaikH1 delete the MagicMirror folder and run the installation script from here
          • M
            MaikH1
            Thanks for the help, really appreciate it.
            That’s what I did, this is the whole message:
            pi@raspberry:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
            $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
            $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
            $$$$$$ $$ | _
            $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
            $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
            $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
            _
            | _
            | _
            | _
            $$ |_| _
            |_| _|_|_| __| _
            / _| _______|
            _
            ____/
            install log being saved to /home/pi/install.log
            this appears not to be a Raspberry Pi 2, 3 or 4, do you want to continue installation (y/N)?y
            Updating packages …
            Installing helper tools …
            Check current Node installation …
            Node currently installed. Checking version number.
            Minimum Node version: v10.1.0
            Installed Node version: v0.10.29
            Node should be upgraded.
            Installing Node.js …
            Reading package lists… Done
            Building dependency tree
            Reading state information… Done
            nodejs is already the newest version.
            The following package was automatically installed and is no longer required:
            libuuid-perl
            Use ‘apt-get autoremove’ to remove it.
            0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
            node version is
            Node.js installation Done! version=v0.10.29
            Check current NPM installation …
            NPM currently installed. Checking version number.
            at node.js:906:3
            Minimum npm version: V6.0.0
            Installed npm version: V
            npm should be upgraded.
            Installing npm …
            at node.js:906:3
            at node.js:906:3
            npm installation Done! version=V
            Cloning MagicMirror …
            Cloning into ‘MagicMirror’…
            remote: Enumerating objects: 284, done.
            remote: Counting objects: 100% (284/284), done.
            remote: Compressing objects: 100% (223/223), done.
            remote: Total 284 (delta 53), reused 136 (delta 48), pack-reused 0
            Receiving objects: 100% (284/284), 386.02 KiB | 0 bytes/s, done.
            Resolving deltas: 100% (53/53), done.
            Checking connectivity… done.
            Cloning MagicMirror Done!
            Installing dependencies …
            at node.js:906:3
            I’m kinda lost here, not sure where the error comes from.
            • swvalentiS
              Use the below raspberry imager and do a fresh install of raspbian and then try the installer from Sam.
              https://www.raspberrypi.org/downloads/
                sdetweil @swvalenti
                @swvalenti nd use the full desktop buster image
                • M
                  MaikH1
                  So not the Raspberry Pi OS (32-bit), but the Raspberry Pi OS Full (32-bit)? ,
                  I’ll try that thank you, last time I used the first one.
                  I’ll be back :), hopefully with good news.
                    sdetweil @MaikH1
                    @MaikH1 correct.
                    • M
                      MaikH1
                      Hmm still no good news.
                      For some reason when I make the image USB with the Full image it isn’t bootable.
                      I tried it with three different USB sticks and wrote the sticks from two different pc’s, but when I try booting/installing from this USB it won’t start. It just gives me the message no bootable device.
                      When I switch to the old USB (with the Raspberry Pi OS (32-bit), it works immediately.
                      Any ideas what I’m doing wrong?
                        sdetweil @MaikH1
                        @MaikH1 make sure u didn’t get the 64 bit version.
                        should be the 1st entry here
                        https://www.raspberrypi.org/downloads/raspberry-pi-os/
