    Failed to install dependencies RPI3 B+
    15 Posts 4 Posters 3.6k Views 3 Watching
    • F Offline
      fredo55
      After flashing my rpi3 B+ with 2018-11-13-raspbian-stretch-full and proceded to run the one-line bash to install MagicMirror2, I got a message of failed to install dependencies. Please help how to uninstall or repair installation. Thanks.
        Mykle1 Project Sponsor Module Developer @fredo55
        @fredo55
        First thing I would try is changing directories into your MagicMirror folder. Open your terminal and enter the following:
        cd MagicMirror
        then
        npm install
        That may be all you need
        • F Offline
          fredo55 @Mykle1
          @Mykle1 Thanks, but …npm command not found
            sdetweil
            Yes, npm isn’t in the base stretch install.
            Run
            sudo apt-get install npm
            Then do the npm install from the mm folder
            Mykle1M F 2 Replies Last reply Reply Quote 0
              Ahh, I assumed that node and npm were already installed. My bad
              • F Offline
                fredo55 @sdetweil
                @sdetweil said in Failed to install dependencies RPI3 B+:
                Run
                npm is installed now , could you elaborate on “then do the npm install from the mm folder”
                Mykle1M S 2 Replies Last reply Reply Quote 0
                  @fredo55
                  Open a terminal window.
                  Change directory by typing cd MagicMirror and enter.
                  Then type npm install and enter.
                  • bheplerB Offline
                    bhepler Module Developer @Mykle1
                    @Mykle1 - They were included in previous Raspbian distributions. Ever since about December or so, the installation script hasn’t been working.
                      sdetweil @fredo55
                      @fredo55 said in Failed to install dependencies RPI3 B+:
                      from the mm folder”
                      mm is short for MagicMirror. Too long to type over and over!
                      • F Offline
                        fredo55
                        Thank you guys, I’ll start from scratch, something else went wrong pm2 giving me a bunch of errors.
                        S F 2 Replies Last reply Reply Quote 0
