    Failed to install dependencies RPI3 B+
    15 Posts 4 Posters 4.6k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @fredo55
      @fredo55
      First thing I would try is changing directories into your MagicMirror folder. Open your terminal and enter the following:
      cd MagicMirror
      then
      npm install
      That may be all you need
      • F Offline
        fredo55 @Mykle1
        @Mykle1 Thanks, but …npm command not found
          Yes, npm isn’t in the base stretch install.
          Run
          sudo apt-get install npm
          Then do the npm install from the mm folder
          Mykle1M F 2 Replies Last reply Reply Quote 0
            Ahh, I assumed that node and npm were already installed. My bad
            • F Offline
              fredo55 @sdetweil
              @sdetweil said in Failed to install dependencies RPI3 B+:
              Run
              npm is installed now , could you elaborate on “then do the npm install from the mm folder”
              Mykle1M S 2 Replies Last reply Reply Quote 0
                @fredo55
                Open a terminal window.
                Change directory by typing cd MagicMirror and enter.
                Then type npm install and enter.
                • bheplerB Offline
                  bhepler Module Developer @Mykle1
                  @Mykle1 - They were included in previous Raspbian distributions. Ever since about December or so, the installation script hasn’t been working.
                    sdetweil @fredo55
                    @fredo55 said in Failed to install dependencies RPI3 B+:
                    from the mm folder”
                    mm is short for MagicMirror. Too long to type over and over!
                    • F Offline
                      fredo55
                      Thank you guys, I’ll start from scratch, something else went wrong pm2 giving me a bunch of errors.
                      S F 2 Replies Last reply Reply Quote 0
                        sdetweil @fredo55
                        @fredo55 if from scratch, make sure to install npm before the MM install
                        F 1 Reply Last reply Reply Quote 1
