    Failed to install dependencies, while trying to install MM2
    10 Posts 3 Posters 710 Views 2 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      Use the below raspberry imager and do a fresh install of raspbian and then try the installer from Sam.
      https://www.raspberrypi.org/downloads/
        sdetweil @swvalenti
        @swvalenti nd use the full desktop buster image
          MaikH1
          So not the Raspberry Pi OS (32-bit), but the Raspberry Pi OS Full (32-bit)? ,
          I’ll try that thank you, last time I used the first one.
          I’ll be back :), hopefully with good news.
            sdetweil @MaikH1
            @MaikH1 correct.
              MaikH1
              Hmm still no good news.
              For some reason when I make the image USB with the Full image it isn’t bootable.
              I tried it with three different USB sticks and wrote the sticks from two different pc’s, but when I try booting/installing from this USB it won’t start. It just gives me the message no bootable device.
              When I switch to the old USB (with the Raspberry Pi OS (32-bit), it works immediately.
              Any ideas what I’m doing wrong?
                sdetweil @MaikH1
                @MaikH1 make sure u didn’t get the 64 bit version.
                should be the 1st entry here
                https://www.raspberrypi.org/downloads/raspberry-pi-os/
