    MMM-Kodi-WebSocket - currently playing song on kodi
    3 Posts 2 Posters 875 Views 2 Watching
      bzzrd
      MMM-Kodi-WebSocket
      this is a fork from https://github.com/buxxi/MMM-MPRIS2-WebSocket to work with Kodi,
      Screenshot:
      Screenshot
      Link
      MMM-Kodi-WebSocket
      This is quick and dirty port, it doesn’t support videos, PR are welcome.
      • ? Offline
        A Former User
        yeah… maybe using this rule it will be better:
        node_helper.js => calculating and using node process
        MMM-module.js => displaying result of the node_helper
        in your case, the risk is :
        • slow down all the display of magicmirror
        • too limited function
        • maybe using node-kodi version into node_helper can help
        For displaying, you can use a part MMM-Spotify code
        don’t forget… all user use an RPI and not an real computer
        verify: RAM/CPU TIME / Traffic / DNS Using
          bzzrd
          Hi Bugsounet,
          as stated it’s just a quick port, given there was no Kodi module.
          I will probably not update it once it reach the level of functionality that I personally need.
          BTW I’m running it on a pi 3a+ and it seems to work ok (but I only have a couple modules) oops nope it’s running on a server
          Thanks for the suggestions anyway.
