    MMM Awesome Alexa installing snowboy.
    44 Posts 4 Posters 14.9k Views 4 Watching
      Ameyalgudkar @sdetweil
      @sdetweil If you could make a copy of your image file or if you have it saved on your disk maybe?
      could you upload it to google cloud or something?
        sdetweil @Ameyalgudkar
        @Ameyalgudkar see the chat messages I sent you
        • ? Offline
          A Former User
          @sdetweil :
          I confirm new update of RPI are now in 5.4.x kernel
          bugs@debian:~/MagicMirror/modules$ ssh pi@192.168.X.XX
          pi@192.168.X.XX's password:
          Linux Raspberry 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l
          I have not see :)
          my npm library can make the build of @bugsounet/snowboy
          pi@Raspberry:~/MagicMirror/modules/MMM-Spotify $ npm install @bugsounet/snowboy
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          > @bugsounet/snowboy@1.6.2 install /home/pi/MagicMirror/modules/MMM-Spotify/node_modules/@bugsounet/snowboy
          > bash scripts/installer.sh
          make : on entre dans le répertoire « /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy/build »
            CXX(target) Release/obj.target/snowboy/lib/snowboy.o
            SOLINK_MODULE(target) Release/obj.target/snowboy.node
            COPY Release/snowboy.node
            COPY /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node
            TOUCH Release/obj.target/action_after_build.stamp
          make : on quitte le répertoire « /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy/build »
          [@bugsounet/snowboy] Do you want to execute electron rebuild ? [Y/n]
          Your choice: y
          ✔ Rebuild Complete
          > @bugsounet/snowboy@1.6.2 postinstall /home/pi/MagicMirror/modules/MMM-Test-Blank/node_modules/@bugsounet/snowboy
          > tsc -p tsconfig.json
          + @bugsounet/snowboy@1.6.2
          added 187 packages from 137 contributors and audited 190 packages in 107.058s
          4 packages are looking for funding
            run `npm fund` for details
          found 0 vulnerabilities
          after official version, i don’t know…
          it’s always been a bit boring to do a build correctly…
          @Ameyalgudkar:
          I see in the error log it’s an x64 build…
          In MagicMirror requirement it’s specified to download the lasted version of raspbian with desktop
          The official website is https://www.raspberrypi.org/ and on the download page there no x64 version
          So you use a beta version with … beta bugs and Complex Module of MagicMirror don’t support x64 version.
          Best way ?
          Like windows and others OS you can’t transform x64 to 32bits (and 32bits to x64 too)
          so best way is reinstall OS with 32bits version
          @bugsounet
          S A 2 Replies Last reply Reply Quote 0
            sdetweil @Guest
            @Bugsounet he is doing on pi, System Linux 5.4.51-v7l+ < — v7l
            i am going to test ubuntu pi 64 bit tomorrow.
            couldn’t wait…
            fix
            need to install libcblas
            sudo apt-get install libatlas-base-dev
            then both my installations using snowboy correctly rebuilt… on ubuntu 64 on pi4.
            • ? Offline
              A Former User
              ah… that’s why my library have no problem for installing :)
              I force it to install with installer lol :)
              nedeed dependencies
                Ameyalgudkar @Guest
                @Bugsounet said in MMM Awesome Alexa installing snowboy.:
                @Ameyalgudkar:
                I am indeed running the 32bit Raspberry Pi OS latest from the official downloads, and not any beta versions.
                I don’t know why the installer is running it in x64.
                  Ameyalgudkar
                  Also now I am facing this problem where, no matter what I do, RPI4 does not take any other sd card boot image and boot that particular system.
                  For instance, My 32gb with working MM and RPI OS 32bit, boot up without any problem.
                  But then, I tried booting with a older build of RPI OS, Ubuntu(https://ubuntu.com/download/raspberry-pi) 32bit for Pi4.
                  Both tried on different sd cards with 8gb/32gb and also reformatting it several times and everything.
                  I feel just so exhausted doing all this and thinking of returning my RPI4 if it has so may issues.
                  • ? Offline
                    A Former User
                    internal firmware :) (eeprom)
                      sdetweil @Guest
                      @Bugsounet doesn’t the newer system apply the firmware update automatically?
                      see here for the firmware test and update procedure
                      https://www.raspberrypi.org/documentation/hardware/raspberrypi/booteeprom.md
                        @sdetweil I tried the boot recovery mentioned in the link, but no luck with that. Still gets stuck in boot and with a red light. no green light. should I try to get a replacement for my device?
                        • 2 / 5
