    MMM Awesome Alexa installing snowboy.
    44 Posts 4 Posters 15.0k Views 4 Watching
    • ? Offline
      A Former User @Ameyalgudkar
      @Ameyalgudkar sure that’s why I do my own … because to complex to build with original repo
      I fork it and correct source file, upgraded some library.
      Add some personal change for simply configuration…
      But i never tested it in this module … maybe there is a few change to do … i don’t know really
      I don’t use Alexa ':(
        Ameyalgudkar @gelaw
        @gelaw no it didn’t. still trying to figure somehow to install Snowboy. just the npm install method is not executing properly. I need the help of dev if I could. but looks like he hasn’t touched his post for a while.
          sdetweil @Ameyalgudkar
          @Ameyalgudkar did u run my script? you keep going thru the steps even if there are errors…
            Ameyalgudkar @sdetweil
            @sdetweil yes I tried, but snowboy not getting installed. here is the errors
            if that would be helpful for you to understand what is actually happening. sorry for the file being very long and tiring.
            • ? Offline
              A Former User
              install nan wih npm
                @Ameyalgudkar no you did NOT use my script, OR follow the instructions… the instructions explicitly tell you to install nan
                https://awesome-alexa.js.org/#/installation
                my script, which is same as the instructions for this module, plus the step to add the one dependency
                over and over we asked if u followed the instructions… but u have not…
                #!/bin/bash
                cd ~/MagicMirror/modules # Navigate to module folder
                if [  ! -e   ~/MagicMirror/modules/MMM-awesome-alexa ]; then
                   git clone https://github.com/dolanmiu/MMM-awesome-alexa.git # Clone this repository
                 fi
                 cd MMM-awesome-alexa # go into the module directory
                 v=$(apt -qq list libatlas-base-dev 2>/dev/null)
                 if [ "$v". == "." ]; then
                   sudo apt-get install libatlas-base-dev
                 fi
                 npm install --only=prod # Install depdendencies
                 cd node_modules
                 rm -rf snowboy # Remove the installed snowboy
                 git clone https://github.com/Kitt-AI/snowboy.git # Manually get snowboy from git
                 cd snowboy # Go into the /snowboy directory
                 rm -rf node_modules
                 npm install nan --save # Make sure you install this in the /snowboy directory        /< --------------------------------------------
                 npm install node-pre-gyp@0.12.0 --save # Make sure you install this in the /snowboy directory
                 npm install # Make sure you install in the /snowboy directory
                 npm run prepublish # Make sure you run this in the /snowboy directory
                 npm install --save-dev electron-rebuild # Make sure you install this in the /snowboy directory
                 npm install nan # Make sure you install this in the /snowboy directory
                 ./node_modules/.bin/electron-rebuild # Build snowboy to your device specifications, in the /snowboy directory
                  @sdetweil now I really dont know what else I have to follow, you can see each and every step I did, I literally copy pasted all the commands as they are. in the same order and directories, I havent included the first few steps mentioned as they get executed every time. I have posted every step which has got errors.
                    @Ameyalgudkar ignore the errors and keep going… it WILL FAIL til the last step…
                    which is why I offered the script to do it for you
                      @sdetweil how should I run the script? I tried the bash c but that didnt worked so did everything from script manually.
                      I will run the script exactly as you say and then will show you result if thats ok. also please let me know in which directory should I run the script.
                        @Ameyalgudkar
                        cut and paste this line into a terminal window
                        bash -c  "$(curl -sL https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0)"
                        • 4 / 5
