    MMM-Face-Reco-DNN
    9 Posts 2 Posters 1.9k Views 2 Watching
    • ParvezP
      Parvez
      docker build --build-arg UID=1000 --build-arg GID=1000 -t mmm-face-reco-dnn-dataset-runner .
      make: docker: Command not found
      make: *** [Makefile:6: image] Error 127
      any one help me ??
      Parvez Ahmed
        sdetweil @Parvez
        @Parvez install docker. google is your friend
        • ParvezP
          Parvez
          @sdetweil thank you so much … you always help me.
          can i use https://forum.magicmirror.builders/topic/10488/mm-server-mode-in-docker-on-raspberry -this link.
          Parvez Ahmed
            sdetweil @Parvez
            @Parvez i don’t understand what you are doing…
            docker for the facereco runner… why?
            and that links makes MM in docker… but why?
            • ParvezP
              Parvez
              @sdetweil i was install docker on google .
              but when i run
              make
              this is the next error .
              Parvez Ahmed
                sdetweil @Parvez
                @Parvez but I don’t know WHY you need to install docker for this module ??? makes no sense
                • ParvezP
                  Parvez
                  @sdetweil when i run
                  python3 encode.py -i ../dataset/ -e encodings.pickle -d hog
                  this command then show this error
                  that’s reason i install docker
                  Parvez Ahmed
                  • ParvezP
                    Parvez
                    Sove any one ?
                    [2020-09-14 21:38:46.198] [ERROR]  Whoops! There was an uncaught exception...
                    [2020-09-14 21:38:46.199] [ERROR]  PythonShellError: [ WARN:0] global /tmp/pip-install-6juqj78y/opencv-python/opencv/modules/videoio/src/cap_gstreamer.cpp (713) open OpenCV | GStreamer warning: Error opening bin: no element "0"
                    [ WARN:0] global /tmp/pip-install-6juqj78y/opencv-python/opencv/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
                    Traceback (most recent call last):
                      File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 106, in <module>
                        frame = imutils.resize(originalFrame, width=500)
                      File "/home/pi/.local/lib/python3.7/site-packages/imutils/convenience.py", line 69, in resize
                        (h, w) = image.shape[:2]
                    AttributeError: 'NoneType' object has no attribute 'shape'
                        at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:254:21)
                        at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:129:32)
                        at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:121:13)
                        at ChildProcess.emit (events.js:200:13)
                        at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12) {
                      executable: 'python3',
                      options: null,
                      script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
                      args: [
                        '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
                        '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
                        '--usePiCamera=0',
                        '--source=0',
                        '--rotateCamera=0',
                        '--method=dnn',
                        '--detectionMethod=hog',
                        '--interval=2000',
                        '--output=0',
                        '--extendDataset=False',
                        '--dataset=modules/MMM-Face-Reco-DNN/dataset/',
                        '--tolerance=0.6'
                      exitCode: 1
                    Parvez Ahmed
                      sdetweil @Parvez
                      @Parvez said in MMM-Face-Reco-DNN:
                      https://github.com/nischi/MMM-Face-Reco-DNN/issues/44
