    MMM-Face-Reco-DNN
    9 Posts 2 Posters 1.6k Views 2 Watching
      sdetweil @Parvez
      @Parvez i don’t understand what you are doing…
      docker for the facereco runner… why?
      and that links makes MM in docker… but why?
      • ParvezP Offline
        Parvez
        @sdetweil i was install docker on google .
        but when i run
        make
        this is the next error .
        Parvez Ahmed
          sdetweil @Parvez
          @Parvez but I don’t know WHY you need to install docker for this module ??? makes no sense
          • ParvezP Offline
            Parvez
            @sdetweil when i run
            python3 encode.py -i ../dataset/ -e encodings.pickle -d hog
            this command then show this error
            > docker build --build-arg UID=1000 --build-arg GID=1000 -t mmm-face-reco-dnn-dataset-runner .
            > make: docker: Command not found
            > make: *** [Makefile:6: image] Error 127
            that’s reason i install docker
            Parvez Ahmed
            • ParvezP Offline
              Parvez
              Sove any one ?
              [2020-09-14 21:38:46.198] [ERROR]  Whoops! There was an uncaught exception...
              [2020-09-14 21:38:46.199] [ERROR]  PythonShellError: [ WARN:0] global /tmp/pip-install-6juqj78y/opencv-python/opencv/modules/videoio/src/cap_gstreamer.cpp (713) open OpenCV | GStreamer warning: Error opening bin: no element "0"
              [ WARN:0] global /tmp/pip-install-6juqj78y/opencv-python/opencv/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
                File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 106, in <module>
                  frame = imutils.resize(originalFrame, width=500)
                File "/home/pi/.local/lib/python3.7/site-packages/imutils/convenience.py", line 69, in resize
                  (h, w) = image.shape[:2]
              AttributeError: 'NoneType' object has no attribute 'shape'
                  at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:254:21)
                  at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:129:32)
                  at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:121:13)
                  at ChildProcess.emit (events.js:200:13)
                  at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12) {
                executable: 'python3',
                options: null,
                script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
                args: [
                  '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
                  '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
                  '--usePiCamera=0',
                  '--source=0',
                  '--rotateCamera=0',
                  '--method=dnn',
                  '--detectionMethod=hog',
                  '--interval=2000',
                  '--output=0',
                  '--extendDataset=False',
                  '--dataset=modules/MMM-Face-Reco-DNN/dataset/',
                  '--tolerance=0.6'
                exitCode: 1
              Parvez Ahmed
                sdetweil @Parvez
                @Parvez said in MMM-Face-Reco-DNN:
                https://github.com/nischi/MMM-Face-Reco-DNN/issues/44
