    MMM-Pages and Alexa
    Scheduled Pinned Locked Moved Forum
    13 Posts 3 Posters 6.0k Views 4 Watching
      radioman
      I have a problem with MMM-Pages (only have MMM-Pages installed) and Alexa
      I’ve already managed to change the 2 sides see code:
              module: 'MMM-pages',
              animationTime: 0,
      		rotationTime: 10000,
      		rotationDelay: 0,
      		pages: 2,
      		         modules:
                          [[ "calendar", "weatherforecast"],
                           [ "MMM-RAIN-RADAR" ]],
                      fixed: ["clock", "MMM-OpenmapWeather", "MMM-page-indicator"],
      Now I would like to switch the pages on or switch over with Alexa see code:
                  module: 'MMM-AlexaControl',
                  position: 'bottom_left',
                  config:{
                      image: false,
                      pm2ProcessName: "mm",
                      refresh: true,
                      restart: true,
                      reboot: false,
                      monitorToggle: true,
                      vcgencmd: 'vcgencmd',
                      deviceName: "Spiegel",
                      startPort: 12000,
                      notifications: [
             			    			    port: 11101,
              					        OnOff: true,
              		 					notification: [["SHOW_RADAR", null],["HIDE_RADAR", null]]
             								port: 11102,
              							OnOff: true,
              							notification: ["PAGE_CHANGED", 0]
             								port: 11103,
              							OnOff: true,
              							notification: ["PAGE_CHANGED", 1]
      Unfortunately that doesn’t work.
      Now the question where is my mistake
      P.S. Alexa finds my devices
      S J 2 Replies Last reply Reply Quote 0
        sdetweil @radioman
        @radioman open the developers window, ctrl-shift-i on the keyboard then select the console tab and look for the notification being sent
        u can filter on the module name, part.in the filter field, Alexa for example.
        and u are saying (All in your language)
        Alexa turn on Seite eins
          radioman
          OK
          is the code correct in terms of reasoning
          Because I cannot switch pages in the Alexa app
            sdetweil @radioman
            @radioman I don’t know. not my module. did the notification get sent? use debug to see
            radar works
            are u using the right command?
            do u need two notifications? one for on and one for off?
              radioman
              Unfortunately, I’m not the kind of programmer that debugging is concerned
              But switching radar is possible in the Alexa app and by voice
                sdetweil @radioman
                @radioman open the console and watch.
                look at the console where u start mm,
                npm start or pm2 logs --lines=???
                ??? is a number 15 default
                gotta learn
                  radioman
                  I also use the MMM remote control module.
                  The Pages tab is empty on the smartphone or in the browser
                    sdetweil @radioman
                    @radioman sorry, don’t use pages
                      radioman
                      I will try tommorow, now its time for me to go to bed
                        JoChef2 Module Developer @radioman
                        @radioman Hi. You made one mistake in the configuration for your page devices. You set OnOff to true. If it’s set to true you can send different notifications for on and off. So you have to set it to false for this two devices. Your config looks then like this:
                            config:{
                                image: false,
                                refresh: true,
                                restart: true,
                                reboot: false,
                                startPort: 12000,
                                notifications: [
                                                        port: 11101,
                                                        OnOff: true,
                                                        port: 11102,
                                                        OnOff: false,
                                                        port: 11103,
                                                        OnOff: false,
                        Instead of this you could also use the pages option and set it to the number of pages you have. You can then change the names in the Alexa app.
                          sdetweil @JoChef2
                          @JoChef2 so, if OnOff is true, then you expect an array of notifications? if false, only one notification, right?
                          you could add a check for array and output a message to help the user…
                          and switch to false…
                            JoChef2 Module Developer @sdetweil
                            @sdetweil Yes you are right. That’s a good idea. I will do it in the next week.
                              radioman
                              :slightly_smiling_face: :ok_hand:
                              Thank You it works
