    MMM-Pages and Alexa
    Scheduled Pinned Locked Moved Forum
    13 Posts 3 Posters 5.5k Views 4 Watching
      radioman
      Unfortunately, I’m not the kind of programmer that debugging is concerned
      But switching radar is possible in the Alexa app and by voice
        sdetweil @radioman
        @radioman open the console and watch.
        look at the console where u start mm,
        npm start or pm2 logs --lines=???
        ??? is a number 15 default
        gotta learn
          radioman
          I also use the MMM remote control module.
          The Pages tab is empty on the smartphone or in the browser
            sdetweil @radioman
            @radioman sorry, don’t use pages
              radioman
              I will try tommorow, now its time for me to go to bed
                JoChef2 Module Developer @radioman
                @radioman Hi. You made one mistake in the configuration for your page devices. You set OnOff to true. If it’s set to true you can send different notifications for on and off. So you have to set it to false for this two devices. Your config looks then like this:
                    module: 'MMM-AlexaControl',
                    position: 'bottom_left',
                    config:{
                        image: false,
                        pm2ProcessName: "mm",
                        refresh: true,
                        restart: true,
                        reboot: false,
                        monitorToggle: true,
                        vcgencmd: 'vcgencmd',
                        deviceName: "Spiegel",
                        startPort: 12000,
                        notifications: [
                                                port: 11101,
                                                OnOff: true,
                                                notification: [["SHOW_RADAR", null],["HIDE_RADAR", null]]
                                                port: 11102,
                                                OnOff: false,
                                                notification: ["PAGE_CHANGED", 0]
                                                port: 11103,
                                                OnOff: false,
                                                notification: ["PAGE_CHANGED", 1]
                Instead of this you could also use the pages option and set it to the number of pages you have. You can then change the names in the Alexa app.
                  sdetweil @JoChef2
                  @JoChef2 so, if OnOff is true, then you expect an array of notifications? if false, only one notification, right?
                  you could add a check for array and output a message to help the user…
                  and switch to false…
                    JoChef2 Module Developer @sdetweil
                    @sdetweil Yes you are right. That’s a good idea. I will do it in the next week.
                      radioman
                      :slightly_smiling_face: :ok_hand:
                      Thank You it works
