    MMM-Pages and Alexa
    Scheduled Pinned Locked Moved Forum
    13 Posts 3 Posters 5.5k Views 4 Watching
      sdetweil @radioman
      @radioman open the developers window, ctrl-shift-i on the keyboard then select the console tab and look for the notification being sent
      u can filter on the module name, part.in the filter field, Alexa for example.
      and u are saying (All in your language)
      Alexa turn on Seite eins
        radioman
        OK
        is the code correct in terms of reasoning
        Because I cannot switch pages in the Alexa app
          sdetweil @radioman
          @radioman I don’t know. not my module. did the notification get sent? use debug to see
          radar works
          are u using the right command?
          do u need two notifications? one for on and one for off?
            radioman
            Unfortunately, I’m not the kind of programmer that debugging is concerned
            But switching radar is possible in the Alexa app and by voice
              sdetweil @radioman
              @radioman open the console and watch.
              look at the console where u start mm,
              npm start or pm2 logs --lines=???
              ??? is a number 15 default
              gotta learn
                radioman
                I also use the MMM remote control module.
                The Pages tab is empty on the smartphone or in the browser
                  sdetweil @radioman
                  @radioman sorry, don’t use pages
                    radioman
                    I will try tommorow, now its time for me to go to bed
                      JoChef2 Module Developer @radioman
                      @radioman Hi. You made one mistake in the configuration for your page devices. You set OnOff to true. If it’s set to true you can send different notifications for on and off. So you have to set it to false for this two devices. Your config looks then like this:
                          module: 'MMM-AlexaControl',
                          position: 'bottom_left',
                          config:{
                              image: false,
                              pm2ProcessName: "mm",
                              refresh: true,
                              restart: true,
                              reboot: false,
                              monitorToggle: true,
                              vcgencmd: 'vcgencmd',
                              deviceName: "Spiegel",
                              startPort: 12000,
                              notifications: [
                                                      port: 11101,
                                                      OnOff: true,
                                                      notification: [["SHOW_RADAR", null],["HIDE_RADAR", null]]
                                                      port: 11102,
                                                      OnOff: false,
                                                      notification: ["PAGE_CHANGED", 0]
                                                      port: 11103,
                                                      OnOff: false,
                                                      notification: ["PAGE_CHANGED", 1]
                      Instead of this you could also use the pages option and set it to the number of pages you have. You can then change the names in the Alexa app.
                        sdetweil @JoChef2
                        @JoChef2 so, if OnOff is true, then you expect an array of notifications? if false, only one notification, right?
                        you could add a check for array and output a message to help the user…
                        and switch to false…
