    9gag module
    3 Posts 2 Posters 1.9k Views
    • ? Offline
      A Former User
      I don´t know if this is the right place but it would be fun to show the post (images) from 9gag.com ir any other site based on RSS xml.
      brobergB 1 Reply Last reply Reply Quote 1
      • brobergB Offline
        broberg Project Sponsor @Guest
        @israel05 there is a lot of issues with a 9gag feed since the images aren’t uniformed, many a times you need to scroll down, but anyways. the newsfeed module, I think is getting support for images as well, that could be used, sort of.
        if you want a quick fix, then use the Instagram module and get the images from 9gag’s instagram account. Yeah I know it’s not the same, but it’s 9gag-light :D
        Here is the instagram module
        https://github.com/kapsolas/MMM-Instagram
        • ? Offline
          A Former User
          Ok, I will create a fork from that Instagram module. About the image size issue, what would you recommend? Cropping the big ones? Scaling them? Any idea?
