    Cant start after update 2.13
    12 Posts 2 Posters 1.5k Views 2 Watching
      SuseGigabyte
      Hi
      After the update the following error message appears.
      I’m a beginner but had no update problems in the last 2 years. I do not know where to start.
      I thank you in advance for your support.
      sh: 1: ./node_modules/.bin/electron: not found
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.13.0 start script.
      npm ERR! /home/pi/.npm/_logs/2020-10-04T16_02_58_708Z-debug.log
        sdetweil @SuseGigabyte
        @SuseGigabyte please tell me more… how did u install, what pi is this?
          SuseGigabyte
          • Raspberry Pi 3 Model B Plus Rev 1.3
          • I updated with “git pull && npm install”
          I have to be honest. After that didn’t work I deleted the folder electron.
          That didn’t work either and in the meantime I don’t really know what to do anymore.
          I hope that I don’t have to do a complete new installation.
          Shame on me.
            @SuseGigabyte lets try to recover
            do
            cd ~/MagicMirror
            npm install electron@6.1.7
            then try to restart mm… there may be other problems to solve
              SuseGigabyte
              after command: npm install electron@6.1.7
              the following message appears:
              npm ERR! Unexpected end of JSON input while parsing near '… “p-locate”: {
              npm ERR! ’
              npm ERR! /home/pi/.npm/_logs/2020-10-04T16_40_18_667Z-debug.log
              after restart mm
              magicmirror@2.13.0 start /home/pi/MagicMirror
              DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
              npm ERR! file sh
              npm ERR!
              npm WARN Local package.json exists, but node_modules missing, did you mean to install?
              npm ERR! /home/pi/.npm/_logs/2020-10-04T16_43_10_392Z-debug.log
                @SuseGigabyte what pi is this?
                also, show me the output of
                lsb_release -a
                uname -a
                node -v
                npm -v
                  SuseGigabyte
                  @sdetweil thank you for your patience.
                  pi@raspberrypi:~/MagicMirror $ lsb_release -a
                  No LSB modules are available.
                  Distributor ID: Raspbian
                  Description: Raspbian GNU/Linux 10 (buster)
                  pi@raspberrypi:~/MagicMirror $ uname -a
                  Linux raspberrypi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
                  pi@raspberrypi:~/MagicMirror $ node -v
                  v10.22.1
                  pi@raspberrypi:~/MagicMirror $ npm -v
                  6.10.3
                    @SuseGigabyte hmmm… looks ok,
                    i ‘suspect’ a bad sd card, but lets try one more time using my upgrade script
                    from here
                    execute this
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                    it will create a log file, MagicMirror/installers/upgrade.log
                      SuseGigabyte
                      @sdetweil You’re a genius. I can’t thank you enough.
                      After hours of blood, sweat and almost tears every thing went o.k.
                      Do I have to do an additional command because of:
                      added 394 packages from 287 contributors and audited 1163 packages in 412.313s
                      found 3 low severity vulnerabilities
                        run `npm audit fix` to fix them, or `npm audit` for details
                      npm install completed - So Okt  4 19:08:08 CEST 2020 on base
                      **upgrade.log**
                      Upgrade started - So Okt  4 19:00:18 CEST 2020
                      system is Linux raspberrypi 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l GNU/Linux
                      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                      user requested to force apply changes
                      doing test run = false
                      saving custom.css
                      remote name = origin
                      upgrading from version 2.13.0 to 2.13.0
                      fetching latest revisions
                      git fetch rc=0
                      current branch = master
                      On branch master
                      Your branch is up to date with 'origin/master'.
                      Changes not staged for commit:
                        (use "git add/rm <file>..." to update what will be committed)
                        (use "git checkout -- <file>..." to discard changes in working directory)
                      	deleted:    config/config.js.sample
                      	modified:   installers/mm.sh
                      	deleted:    modules/default/clock/README.md
                      	modified:   modules/default/clock/clock.js
                      	deleted:    modules/default/clock/clock_styles.css
                      	modified:   modules/default/compliments/compliments.js
                      	modified:   package-lock.json
                      	modified:   package.json
                      Untracked files:
                        (use "git add <file>..." to include in what will be committed)
                      	core
                      	css/custom.css_Back
                      	css/custom.css_Backup
                      	css/save_custom.css
                      	installers/pm2_MagicMirror.json
                      	js/socketclient.js_heute
                      	js/socketclient.js_mod
                      	js/socketclient.js_modified
                      	js/socketclient.js_org
                      	modules/default/back_clock/
                      	modules/default/compliments/compliments.js_org
                      	package-lock.json_back
                      	package-lock.json_back_1
                      	package.json_back
                      	package.json_back_1
                      no changes added to commit (use "git add" and/or "git commit -a")
                      there are 5 local files that are different than the master repo
                         installers/mm.sh
                         package-lock.json
                         package.json
                      save/restore files selection = y
                      Speicherte Arbeitsverzeichnis und Index-Status WIP on master: 3dbe8bf Merge pull request #2143 from MichMich/develop
                      test merge result rc='' , if empty, no conflicts
                      executing merge, apply specified
                      merge result rc= 0
                       Already up to date.
                      processor architecture is armv7l
                      updating MagicMirror runtime, please wait
                      > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
                      > node ./msg.js
                      Attention
                          Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
                          For more details goto: https://www.npmjs.com/package/console-stamp/v/next
                      > electron@6.1.12 postinstall /home/pi/MagicMirror/node_modules/electron
                      > node install.js
                      > magicmirror@2.13.0 install /home/pi/MagicMirror
                      > echo "Installing vendor files ...
                      " && cd vendor && npm install --loglevel=error
                      audited 24 packages in 2.478s
                      found 0 vulnerabilities
                      > magicmirror@2.13.0 postinstall /home/pi/MagicMirror
                      > npm run install-fonts && echo "MagicMirror installation finished successfully!
                      > magicmirror@2.13.0 install-fonts /home/pi/MagicMirror
                      > echo "Installing fonts ...
                      " && cd fonts && npm install --loglevel=error
                      audited 1 package in 2.715s
                      fixing sandbox permissions
                      downloading dumpactivemodules script
                      processing dependency changes for active modules with package.json files
                      processing for module netatmo please wait
                        @SuseGigabyte no additional commands required
                        in the future, please use code wrapper for posts with messages like this… (mark the text and hit the </> button)
