    trouble with MMM-GoogleTrafficTimes
    traffic
    39 Posts 3 Posters 8.9k Views 3 Watching
    • L Offline
      laschalkh @sdetweil
      np, I appreciate all the help. Here are the results:
      pi@raspberrypi:~ $ cd MagicMirror/
      pi@raspberrypi:~/MagicMirror $ ls -laF run-start.sh
      -rwxr-xr-x 1 pi pi 2980 Oct 15 16:56 run-start.sh*
      pi@raspberrypi:~/MagicMirror $ uname -a
      Linux raspberrypi 5.4.51+ #1333 Mon Aug 10 16:38:02 BST 2020 armv6l GNU/Linux
      pi@raspberrypi:~/MagicMirror $ pgrep Xorg
      pi@raspberrypi:~/MagicMirror $ which chromium-browser
        sdetweil @laschalkh
        @laschalkh said in trouble with MMM-GoogleTrafficTimes:
        pgrep Xorg
        are both empty
        which means you don’t have the graphical desktop running., looks like you are in cli mode
        u MUST have the desktop to run MM…, browser requires graphics.
        reflash the sd card with the full desktop image of buster
        top left here
        https://www.raspberrypi.org/downloads/raspberry-pi-os/
        Raspberry Pi OS (32-bit) with desktop and recommended software
        • L Offline
          laschalkh
          ok, I’ll try it, but I may need to grab another pi. Not sure the zero can handle the full version
            sdetweil @laschalkh
            @laschalkh it will work, depends on what u want to do… i have one running all day every day, default modules
            • L Offline
              laschalkh @sdetweil
              cool, I just want a couple modules so hopefully won’t b a problem. It’s flashing now so I’ll reach out after it’s running and installed
              • L Offline
                laschalkh
                Hi Sam,
                ok, got it all running and it is working. Your script works very well. I tried adding MMM-GoogleMapsTraffic as well and that seems to kill the mirror. It says it can’t find the config file. As long as I leave that out, it’s working.
                  sdetweil @laschalkh
                  @laschalkh u might want my version of Googlemapstraffic, as the original is broken
                  https://github.com/sdetweil/MMM-GoogleMapsTraffic
                  • L Offline
                    laschalkh
                    yea, that’s the one I’m trying. I just tried that module only and it’s not working. I ran the install again and it is warning about grunt styles not being installed. Seems like it’s missing parts.
                      sdetweil @laschalkh
                      @laschalkh thats noise
                      you did the git clone
                      cd
                      and then npm install
                      right?
                      so, whats your config section look like… no one has had trouble installing it, it was a run problem I fixed…
                      • L Offline
                        laschalkh
                        yup, went through and did the install and such
                                                module: 'MMM-GoogleMapsTraffic',
                                                position: 'bottom_left',
                                                        key: '< my key>',
                                                        lat: < my lat>,
                                                        lng: < my long>,
                                                        height: '300px',
                                                        width: '300px'
                                                        styledMapType: "transparent",
                                                        disableDefaultUI: true,
                                                        backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                                        markers: [
        lat: <my lat>,
        lng: <my long>,
        fillColor: '#9966ff'
                        • 3 / 4
