    trouble with MMM-GoogleTrafficTimes
    traffic
    39 Posts 3 Posters 9.3k Views 3 Watching
    • L Offline
      laschalkh @sdetweil
      np, I appreciate all the help. Here are the results:
      pi@raspberrypi:~ $ cd MagicMirror/
      pi@raspberrypi:~/MagicMirror $ ls -laF run-start.sh
      -rwxr-xr-x 1 pi pi 2980 Oct 15 16:56 run-start.sh*
      pi@raspberrypi:~/MagicMirror $ uname -a
      Linux raspberrypi 5.4.51+ #1333 Mon Aug 10 16:38:02 BST 2020 armv6l GNU/Linux
      pi@raspberrypi:~/MagicMirror $ pgrep Xorg
      pi@raspberrypi:~/MagicMirror $ which chromium-browser
        sdetweil @laschalkh
        @laschalkh said in trouble with MMM-GoogleTrafficTimes:
        pgrep Xorg
        are both empty
        which means you don’t have the graphical desktop running., looks like you are in cli mode
        u MUST have the desktop to run MM…, browser requires graphics.
        reflash the sd card with the full desktop image of buster
        top left here
        https://www.raspberrypi.org/downloads/raspberry-pi-os/
        Raspberry Pi OS (32-bit) with desktop and recommended software
        • L Offline
          laschalkh
          ok, I’ll try it, but I may need to grab another pi. Not sure the zero can handle the full version
            sdetweil @laschalkh
            @laschalkh it will work, depends on what u want to do… i have one running all day every day, default modules
            • L Offline
              laschalkh @sdetweil
              cool, I just want a couple modules so hopefully won’t b a problem. It’s flashing now so I’ll reach out after it’s running and installed
              • L Offline
                laschalkh
                Hi Sam,
                ok, got it all running and it is working. Your script works very well. I tried adding MMM-GoogleMapsTraffic as well and that seems to kill the mirror. It says it can’t find the config file. As long as I leave that out, it’s working.
                  sdetweil @laschalkh
                  @laschalkh u might want my version of Googlemapstraffic, as the original is broken
                  https://github.com/sdetweil/MMM-GoogleMapsTraffic
                  • L Offline
                    laschalkh
                    yea, that’s the one I’m trying. I just tried that module only and it’s not working. I ran the install again and it is warning about grunt styles not being installed. Seems like it’s missing parts.
                      sdetweil @laschalkh
                      @laschalkh thats noise
                      you did the git clone
                      cd
                      and then npm install
                      right?
                      so, whats your config section look like… no one has had trouble installing it, it was a run problem I fixed…
                      • L Offline
                        laschalkh
                        yup, went through and did the install and such
                                                module: 'MMM-GoogleMapsTraffic',
                                                position: 'bottom_left',
                                                        key: '< my key>',
                                                        lat: < my lat>,
                                                        lng: < my long>,
                                                        height: '300px',
                                                        width: '300px'
                                                        styledMapType: "transparent",
                                                        disableDefaultUI: true,
                                                        backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                                        markers: [
        lat: <my lat>,
        lng: <my long>,
        fillColor: '#9966ff'
                          sdetweil @laschalkh
                          @laschalkh how are u specifying lat/lng (in both places, right)
                          like this (good)
                          lat:30.4623841,
                          or this (bad)
                          lat:"30.4623841",
                          • L Offline
                            laschalkh
                            yup, not quoted
                              sdetweil @laschalkh
                              @laschalkh ok, so what is the error?
                              • L Offline
                                laschalkh
                                magicmirror@2.13.0 start /home/pi/MagicMirror
                                ./run-start.sh $1 “dev”
                                [2020-10-16 11:15:36.565] [LOG] Starting MagicMirror: v2.13.0
                                [2020-10-16 11:15:36.775] [LOG] Loading config …
                                [2020-10-16 11:15:36.823] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:73
                                styledMapType: “transparent”,
                                SyntaxError: Unexpected identifier
                                at Module._compile (internal/modules/cjs/loader.js:723:23)
                                at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                                at Module.load (internal/modules/cjs/loader.js:653:32)
                                at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                at Module.require (internal/modules/cjs/loader.js:692:17)
                                at require (internal/modules/cjs/helpers.js:25:18)
                                at loadConfig (/home/pi/MagicMirror/js/app.js:70:12)
                                at App.start (/home/pi/MagicMirror/js/app.js:217:3)
                                at Object. (/home/pi/MagicMirror/serveronly/index.js:4:5)
                                [2020-10-16 11:15:36.862] [LOG] Loading module helpers …
                                [2020-10-16 11:15:37.496] [LOG] Initializing new module helper …
                                [2020-10-16 11:15:37.507] [LOG] Module helper loaded: updatenotification
                                [2020-10-16 11:15:37.525] [LOG] No helper found for module: helloworld.
                                [2020-10-16 11:15:37.531] [LOG] All module helpers loaded.
                                [2020-10-16 11:15:39.089] [LOG] Starting server on port 8080 …
                                [2020-10-16 11:15:39.324] [LOG] Server started …
                                [2020-10-16 11:15:39.335] [LOG] Connecting socket for: updatenotification
                                [2020-10-16 11:15:39.346] [LOG] Sockets connected & modules started …
                                [2020-10-16 11:15:39.354] [LOG]
                                  sdetweil @laschalkh
                                  rule number 1 debugging syntax errors:
                                  IF you see ’ Unexpected identifier’, find the line number
                                  config.js:73
                                  back up one line (72), and check for the missing , at the end
        width: '300px'                                   <  ---
                                  • L Offline
                                    laschalkh
                                    I see it, damn, I’ve stared at that for way too long, rebooting…
                                      sdetweil @laschalkh
                                      @laschalkh you don’t need to reboot all the time, just restart mm…
                                      • L Offline
                                        laschalkh
                                        it’s working now. Thank you for all of the help!
                                        Kevin
                                          mrhurley
                                          I have been playing around with this and it works well. However, it doesn’t like when you trying to get times for another travel mode. It will change the icons, but the times are always for driving. I played with the file and forced the cycling mode but then it won’t show up on the screen. I think the issue is the Distance Matrix API returns unexpected information for the other modes.
                                          Can someone help point me in the right direction? Thanks
