    Low voltage warning
    3 Posts 2 Posters 807 Views 2 Watching
      requiemmg
      I am using 2x exactly the same build for my MagicMirrors.
      On one of them, I have a constant low voltage warning (white text field displayed in the top right corner, does not go away with disabling warnings in the boot.config.
      I am really confused about this, because on the other Mirror, no problems.
      I use a 3b+ and a power supply with 5.1V/3A output, and I also exchanged supllies between thge two mirrors, but still the same.
      Anyone got an idea how to get rid of this?
      FoziF 1 Reply Last reply Reply Quote 0
      • FoziF Offline
        Fozi Project Sponsor @requiemmg
        @requiemmg switch the PSU and see if the warning appears on the other mirror, too. Chances that the PSU is faulty.
          requiemmg
          As I said, I already switched the PSUs. Raspi A always displays the error, Raspi B not. No matter which PSU is being used.
