    "absolute" does not mean absolute in default calendar module
    20 Posts 4 Posters 3.0k Views 4 Watching
      sdetweil @Alvinger
      @Alvinger ok. the latest fixes, Monday did address full day recurring
      I would be happy to see the cal
      • BKeyportB Offline
        BKeyport Module Developer
        Absolute isn’t absolute, without other tags…
        getRelative and urgency also need to be set.
        // Force Absolute to Absolute all the time, michmich *really* hates solid dates, apparently.
        timeformat: "absolute",
        getRelative: 0,
        urgency: 0 ,
        AlvingerA 1 Reply Last reply Reply Quote 0
        • ? Offline
          A Former User
          This post is deleted!
          AlvingerA 2 Replies Last reply Reply Quote 0
          • AlvingerA Offline
            Alvinger @Guest
            @hango correct, that’s all I did. But I changed it in all MM files. If I just knew exactly which files are executed in the browser I could have changed just those. As the iPads require a server (which can handle the latest ES) one only needs to change the browser-executed files.
            • AlvingerA Offline
              Alvinger @BKeyport
              @BKeyport well almost! I have this exact config but running events are still changed to “ends in xx min”! And all day events still shows as “today”
              I’ve done a rewrite of the relevant section of calendar.js but can’t use my github clone repo to make a PR.
              S BKeyportB 2 Replies Last reply Reply Quote 0
                sdetweil @Alvinger
                @Alvinger u needed to.make a fork, and then clone that. fork button is upper right
                • AlvingerA Offline
                  Alvinger @sdetweil
                  @sdetweil I know. But I have already forked the MM master and made changes to use my Ipad 2. How do I make a new branch containing the latest MM development files? My plan was to wait until the new version was merged into Master and then do my Ipad2-related changes. Github won’t allow me to have multiple repositories with the same name.
                  • AlvingerA Offline
                    Alvinger
                    @sdetweil I have created a PR for the proposed calendar changes.
                      sdetweil @Alvinger
                      @Alvinger what branch did u use when u made your changes?
                      • AlvingerA Offline
                        Alvinger @Guest
                        @hango I just checked the development branch of MM and changed the following files. It now works perfectly on my Ipad2. Of course, if you use non-default modules you may have to edit them as well.
                        • modified: js/electron.js
                        • modified: js/translator.js
                        • modified: modules/default/alert/alert.js
                        • modified: modules/default/alert/notificationFx.js
                        • modified: modules/default/calendar/calendar.js
                        • modified: modules/default/compliments/compliments.js
                        • modified: modules/default/newsfeed/newsfeed.js
                        • modified: modules/default/updatenotification/updatenotification.js
                        • modified: modules/default/weather/weather.js
                        • modified: modules/default/weather/weatherobject.js
                        • modified: modules/default/weatherforecast/weatherforecast.js
                        The changes I made to the above files are:
                        1. Changed all “let” to “var”.
                        2. Changed all “() =>” to “function ()”. Also, you have to make sure that the expression following “function ()” is enclosed in curly braces “{}”, i.e. no one-liners!
