    new update Assistant2Display
    27 Posts 4 Posters 7.1k Views 4 Watching
      raf @sdetweil
      i am thinking of an issue with the electron rebuild, if i disable Assistant2Display in the config.js the mirror will boot normally but if i enable it back in the config.js i only get a black image
      • ? Offline
        A Former User
        when you clone the repo, all needed files have the the executable flag … you have change it so … we give the way … now search
        All of my module have same scheme… if there is some probleme all of my module will be impected
        It’s not the case For you information : A2D is downloaded +/- 500X per week
        So now you have make a mismake … now search, you have the way …
        we can’t tell you better and we can’t do better ;)
        we are not magican
        Or like you says :
        @raf said in new update Assistant2Display:
        I’ll just remove the google assistant and assistant2display because I can’t find the error (then just a mirror without assistant)
        it’s the best choice for you BUT don’t ask to me or @sdetweil some help in this case
        and plz don’t notify me in future
          raf
          problem finally solved
            banbutcher
            @raf how did you solve it, incase anyone else hase the same issue?
            • ? Offline
              A Former User @banbutcher
              @banbutcher… It s not an issue
                raf
                I solved it by disabling the Assistant2Display in the config.js and then after removing the folder in the modules folder,
                then done the installation back git clone … and enabled the module back in the config.js and what changed in the config changed to mine
                • ? Offline
                  A Former User @raf
                  Mouahah!
                  Rassure me… When you have a problem with you computer you don’t change it? Mouahahah
                  So for resume… You have change installer file to don’t execute it
                  Result… You disable it… Delete de directory… Git clone it… Reinstall it…
                  Yeahh ;)
                  Mouahahah lost time
                  I think I’m so stupid… When I do an error… I have to try your method… But I will lost all my work! Mouahahahahah
                  You do a command… You don’t know the signification… Result we give the way… And you don’t find mouahahah
                  The command in the installer directory For repair your mismake serial command is:
                  ‘chmod +x *.sh’
                  And pouuf it repair… You have Wikipedia… You don’t want to read it… A single search on Google and you have the result… To lazy to do this mouahahahah
                  Sorry, mouahahahah
