    MMM-Hotword + google assistant
    9 Posts 2 Posters 1.9k Views 2 Watching
    • O Offline
      ondrax
      Hello i have problem with MM.
      I build my first MM. Working excelent, but i have problem with module Hotword. I search some manual how inmplement hotword + google assistant. I have issue with install hotword.
      Can I use some new alternative module?
      ![0_1606388838979_mm.jpg](Uploading 100%)
      • O Offline
        ondrax
        IMG LOG https://ibb.co/BjmVnWB
        • ? Offline
          A Former User @ondrax
          @ondrax and what says the repo of hotword?
          • O Offline
            ondrax
            Sorry i don’t know what you mean?
            • ? Offline
              @ondrax actually Hotword is deprecied and not maintened
              • O Offline
                ondrax
                Well I understand. There is an alternative that can work with google assistant?
                • ? Offline
                  @ondrax Google Assistant?
                  • O Offline
                    ondrax
                    I would like use your MMM-AssistantMk2,
                    now i read then No MMM-Hotword needed in description, but on YT video they use MMM and after instalation use AssistantMk2.
                    Thank you.
                    • O Offline
                      ondrax
                      Sorry my mistake.
                      I consider this module like OUTDATED and deprecied.
                      If you want an modern Assistant use: MMM-GoogleAssistant and MMM-Assistant2Display extension
                      I try new version.
