    MMM-BackgroundSlideshow gradient and horizontalGradient not working
    backgrounderrorgradientslideshow
    3 Posts 1 Posters 1.9k Views 1 Watching
    • M
      MajorC Project Sponsor
      Hi all and @darick_c ,
      I would like to use MMM-BackgroundSlideshow to show some pictures full screen.
      In the config I use:
      gradient: [ "rgba(0, 0, 0, 0.75) 0%", "rgba(0, 0, 0, 0) 20%", "rgba(0, 0, 0, 0) 80%", "rgba(0, 0, 0, 0.75) 100%" ]
      horizontalGradient: [ "rgba(1, 0, 0, 0.75) 0%", "rgba(0, 0, 0, 0) 30%", "rgba(0, 0, 0, 0) 70%", "rgba(1, 0, 0, 0.75) 100%" ]
      So, there should be, top to bottom, a darker area from 0% to 20% of the screen and from 80% to 100%, right?
      And from left to right, there should be a darker area from 0% to 30% and from 70% to 100% of the screen.
      I put a 100% white picture in the background, to see where the darker area is.
      I don’t know if I understand the gradient, horizontalGradient wrong or something else is not correct.
      Full config:
      			module: 'MMM-BackgroundSlideshow',
      			position: 'fullscreen_below',
      				imagePaths: ['modules/MMM-BackgroundSlideshow/BackgroundImages'],
      				transitionImages: true,
      				transitions: ['opacity'],
      				randomizeImageOrder: true,
      				slideshowSpeed: 500000,
      				gradient: [ "rgba(0, 0, 0, 0.75) 0%", "rgba(0, 0, 0, 0) 20%", "rgba(0, 0, 0, 0) 80%", "rgba(0, 0, 0, 0.75) 100%" ], //von oben nach unten, % = wo im Bildschirm startet es
      				horizontalGradient: [ "rgba(1, 0, 0, 0.75) 0%", "rgba(0, 0, 0, 0) 30%", "rgba(0, 0, 0, 0) 70%", "rgba(1, 0, 0, 0.75) 100%" ] //von links nach rechts, % = wo im Bildschirm startet es
      • M
        I solved it by myself. So here for the rest of the world or maybe for myself in a couple of months.
        The following config is working:
        				gradientDirection: 'both',
        				gradient: [ "rgba(0, 0, 0, 0.00) 0%", "rgba(0, 0, 0, 0.00) 0%", "rgba(0, 0, 0, 0.00) 90%", "rgba(0, 0, 0, 0.75) 100%" ], //von oben nach unten, % = wo im Bildschirm startet es
        				horizontalGradient: [ "rgba(0, 0, 0, 0.75) 0%", "rgba(0, 0, 0, 0) 15%", "rgba(0, 0, 0, 0.00) 85%", "rgba(0, 0, 0, 0.75) 100%" ] //von links nach rechts, % = wo im Bildschirm startet es
        In addition, you have to change a line in the MMM-BackgroundSlideshow.js file in the getDom function (line 316)
        OLD: this.createGradientDiv('right', this.config.gradient, wrapper);
        NEW: this.createGradientDiv('right', this.config.horizontalGradient, wrapper);
        I will put this on GitHub as well.
        • M
          Hello World,
          can someone give me a hand? I am sure I am not the only one using this module :-)
          • M
