    Change the modul position remote with api or something similar!
    7 Posts 2 Posters 1.6k Views 2 Watching
    • P Offline
      pi-user
      Hello everyone,
      I have a quick question. Is there a way to change the positions of the modules remotely? Is there an API for controlling the modules that are on the screen? An example: I want to move the position of the Weather module from the left to the right. I would like to remotely set the position of the weather module to right and the MM website should update itself automatically. I don’t want to restart the service manually.
      Thank you for the answers.
        sdetweil @pi-user
        @pi-user there is a module that does this
        https://github.com/Toreke/MMM-Dynamic-Modules
        it allows other modules to send notifications to move modules. I do not think it saves the info
        • P Offline
          pi-user
          Thanks for the link. I don’t think the config.js file will be changed remotely and the MM web server will start automatically.
            sdetweil @pi-user
            @pi-user correct it does not change it permanently
            • P Offline
              pi-user
              I did not understand how to use this module. How can I access this module remotely from another PC in the network?
                sdetweil @pi-user
                @pi-user u would have to use another module, like remote-control and have it send the position notification
                • P Offline
                  pi-user
                  Thank you.:folded_hands:
                  Then I have to use the remote-control module in a Javascript code to be able to access MMM-Dynamic-Modules. Maybe I can find a code example somewhere on the internet that makes it work too.
