    MM only server version working due to issues with config file
    33 Posts 3 Posters 12.5k Views 3 Watching
    • L Offline
      legan
      Hey guys
      right now I am setting up my Magic Mirror for the second time. The first time everything worked smoothly and first modules were running without any problems. But now after installing it for the second time, I cannot start the mirror with “npm start”. It always says I have to create a config file. But I already did as described in the instructions. I also set up a copy of it as recommended. However, the server version is working and I also can add new modules which are running on the server version without any problems.
      Do you have an idea what I did wrong or how I can solve this issue?
      Thank you in advance! :)
        sdetweil @legan
        @legan if the server ver runs, then its not a config.js problem, but most likely a failure to run npm install in some module folder…
        npm start messages should show you ‘unable to locate module’
        • L Offline
          legan
          @sdetweil thank you so much for your fast reply!
          Do you have an concrete idea what I should do to fix it?
            sdetweil @legan
            @legan i don’t see the config error…
              sdetweil @legan
              @legan you are connected via ssh, and using DISPLAY=:0, so should be displaying on pi monitor
              • L Offline
                legan
                exactly and I got the config error on the monitor which is connected to the pi
                  sdetweil @legan
                  @legan eh? take a pic?
                  L 2 Replies Last reply Reply Quote 0
                  • L Offline
                    legan @sdetweil
                    This post is deleted!
                    • L Offline
                      legan @sdetweil
                        sdetweil @legan
                        @legan pic the icon with the sun over the mountain, folded upper right corner
                        • L Offline
                          legan @sdetweil
                            sdetweil @legan
                            @legan weird, can u show results of
                            ls ~/MagicMirror/config -laF
                            • L Offline
                              legan @sdetweil
                              Of course, here you are :)
                                sdetweil @legan
                                @legan ok, on that error screen, ctrl-shift-i to open the developers window, then select the console tab and scroll up there should be an error at the top…
                                the code does
                                try {
                                			fs.accessSync(configFilename, fs.F_OK);  // make sure we have permission to access file
                                			var c = require(configFilename);    // load and parse config
                                			checkDeprecatedOptions(c);
                                			var config = Object.assign(defaults, c);   // overlay defaults with config
                                			callback(config);   // send back the loaded config
                                		} catch (e) {  // some error above
                                			if (e.code === "ENOENT") {    // if file not found
                                				Log.error(Utils.colors.error("WARNING! Could not find config file. Please create one. Starting with default configuration."));
                                			} else if (e instanceof ReferenceError || e instanceof SyntaxError) {  // got a syntax error
                                				Log.error(Utils.colors.error("WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: " + e.stack));
                                			} else {  // everything else
                                				Log.error(Utils.colors.error("WARNING! Could not load config file. Starting with default configuration. Error found: " + e));
                                			callback(defaults);    // < this is sending back the module config that displays the error you see
                                • L Offline
                                  legan
                                  @sdetweil thanks you very much! Ok, I opened the developer window as you suggested and attached the screenshots of the errors. Where exactly should I paste your code snippet?2.JPG 3.JPG 4.JPG
                                    sdetweil @legan
                                    @legan I was just showing what the code DOES…
                                    custom.css error is because its not there by default…
                                    • L Offline
                                      legan @sdetweil
                                      @sdetweil ok sorry, I am not very familiar with java script yet…
                                        sdetweil
                                        very weird… lets do this
                                        cd ~/MagicMirror
                                        npm run config:check
                                        • L Offline
                                          legan @sdetweil
                                          @sdetweil no syntax errors…
                                            sdetweil @legan
                                            @legan said in MM only server version working due to issues with config file:
                                            thx… as expected…
                                            can u check the filename , rename config.js and make sure no leading/trailing space
                                            also can u try with a browser on pi to open
                                            file:///home/pi/MagicMirror/config/config.js
