    mmap() failed: Cannot allocate memory
    15 Posts 2 Posters 5.8k Views 2 Watching
    • E Offline
      Egnos
      my MM seems to work correctly but during its execution I see many strings on the terminal:
      mmap () failed: Cannot allocate memory
      Below I attach the log:
      pi@MagicMirror:~/MagicMirror $ npm start
      > magicmirror@2.10.1 start /home/pi/MagicMirror
      > ./run-start.sh
      [01:56:08.640] [LOG]    Starting MagicMirror: v2.10.1
      [01:56:08.652] [LOG]    Loading config ...
      [01:56:08.663] [LOG]    Loading module helpers ...
      [01:56:08.676] [LOG]    Initializing new module helper ...
      [01:56:08.677] [LOG]    Module helper loaded: MMM-Page-Selector
      [01:56:08.680] [LOG]    No helper found for module: MMM-page-indicator.
      [01:56:08.681] [LOG]    No helper found for module: alert.
      [01:56:08.682] [LOG]    No helper found for module: clock.
      [01:56:09.351] [LOG]    Initializing new module helper ...
      [01:56:09.352] [LOG]    Module helper loaded: calendar
      [01:56:09.406] [LOG]    Initializing new module helper ...
      [01:56:09.408] [LOG]    Module helper loaded: MMM-newsfeedtouch
      [01:56:09.420] [LOG]    Initializing new module helper ...
      [01:56:09.422] [LOG]    Module helper loaded: mmm-suncalc
      [01:56:10.159] [LOG]    Initializing new module helper ...
      [01:56:10.160] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
      [01:56:10.717] [LOG]    Initializing new module helper ...
      [01:56:10.718] [LOG]    Module helper loaded: MMM-DarkSkyForecast
      [01:56:11.278] [LOG]    Initializing new module helper ...
      [01:56:11.279] [LOG]    Module helper loaded: MMM-AQI
      [01:56:11.802] [LOG]    Initializing new module helper ...
      [01:56:11.802] [LOG]    Module helper loaded: MMM-Todoist
      [01:56:11.803] [LOG]    No helper found for module: MMM-Globe.
      [01:56:11.804] [LOG]    No helper found for module: MMM-EARTH-Live.
      [01:56:11.811] [LOG]    No helper found for module: MMM-ISS-Live.
      [01:56:11.814] [LOG]    Initializing new module helper ...
      [01:56:11.815] [LOG]    Module helper loaded: MMM-ISS
      [01:56:11.816] [LOG]    No helper found for module: planetrise.
      [01:56:11.820] [LOG]    Initializing new module helper ...
      [01:56:11.821] [LOG]    Module helper loaded: MMM-Lunartic
      [01:56:11.821] [LOG]    All module helpers loaded.
      [01:56:11.822] [LOG]    Starting server on port 8080 ...
      [01:56:11.846] [LOG]    Server started ...
      [01:56:11.848] [LOG]    Connecting socket for: MMM-Page-Selector
      [01:56:11.851] [LOG]    Connecting socket for: calendar
      [01:56:11.853] [LOG]    Starting node helper for: calendar
      [01:56:11.854] [LOG]    Connecting socket for: MMM-newsfeedtouch
      [01:56:11.856] [LOG]    Starting module: MMM-newsfeedtouch
      [01:56:11.859] [LOG]    Connecting socket for: mmm-suncalc
      [01:56:11.860] [LOG]    Starting node_helper for mmm-suncalc:
      [01:56:11.862] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
      [01:56:11.865] [LOG]    Connecting socket for: MMM-DarkSkyForecast
      [01:56:11.867] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
      [01:56:11.868] [LOG]    Connecting socket for: MMM-AQI
      [01:56:11.871] [LOG]    MMM-AQI helper started ...
      [01:56:11.872] [LOG]    Connecting socket for: MMM-Todoist
      [01:56:11.874] [LOG]    Starting node helper for: MMM-Todoist
      [01:56:11.877] [LOG]    Connecting socket for: MMM-ISS
      [01:56:11.881] [LOG]    Starting node_helper for: MMM-ISS
      [01:56:11.884] [LOG]    Connecting socket for: MMM-Lunartic
      [01:56:11.887] [LOG]    Starting node_helper for: MMM-Lunartic
      [01:56:11.888] [LOG]    Sockets connected & modules started ...
      [01:56:12.119] [LOG]    Launching application.
      [01:56:15.611] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/53/Italy_Holidays.ics - Interval: 300000
      [01:56:15.664] [LOG]    Create new news fetcher for url: https://www.astronomiamo.it/DivulgazioneAstronomica/Astronomiamo-RSS/Notizie - Interval: 300000
      [01:56:15.788] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/223/F1_Schedule_2018.ics - Interval: 300000
      [01:56:15.791] [LOG]    Create new news fetcher for url: https://www.ansa.it/sito/ansait_rss.xml - Interval: 300000
      [01:56:15.900] [ERROR]  (node:3678) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [01:56:15.901] [ERROR]  (node:3678) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [01:56:16.249] [LOG]    Refreshed access token because it has expired. Expired at: 01:56:15 now is: 01:56:16
      [01:56:20.864] [LOG]    Use existing news fetcher for url: https://www.astronomiamo.it/DivulgazioneAstronomica/Astronomiamo-RSS/Notizie
      [01:56:22.568] [LOG]    Use existing news fetcher for url: https://www.ansa.it/sito/ansait_rss.xml
      [01:56:23.106] [LOG]    Refreshed access token because it has expired. Expired at: 01:56:22 now is: 01:56:23
      mmap() failed: Impossibile allocare memoria
      What is happening?
      Can you help me?
      Happy New Year to all!
      • E Offline
        Egnos
        UP!
        Can someone help me? :disappointed_but_relieved_face:
          sdetweil
          no idea… would take a bit of debugging
          in a terminal window do
          free -m
          lsb_release -a
          uname -a
          • E Offline
            Egnos @sdetweil
            @sdetweil I’ve done a lot of testing and I think the problem is audio.
            For now I have found a configuration that does not give many problems.
            Could it be a resource issue?
              sdetweil @Egnos
              @Egnos could be. the error is no memory
              • E Offline
                Egnos
                @sdetweil said in mmap() failed: Cannot allocate memory:
                No memory do you mean RAM or SD memory?
                  sdetweil @Egnos
                  @Egnos ram technically heap.
                  could be a bug in the module or a library it uses
                  • E Offline
                    Egnos
                    I found the follow procedure for prevent Raspberry Pi memory allocation failure.
                    link
                    1. All commands should be issued as root:
                    sudo su
                    1.5) If you have previously uninstalled dphys-swapfile:
                    apt-get install dphys-swapfile
                    1. Set the swap file size to double the amount on RAM:
                    echo "CONF_SWAPSIZE=512" > /etc/dphys-swapfile
                    dphys-swapfile setup
                    If you have 512 MB RAM on the Pi then set swapsize to 1024.
                    1. Enable swap
                    dphys-swapfile swapon
                    1. Exit the root shell
                    exit
                    And that’s it.
                    Could be the solution to use the SWAP file?
                      sdetweil @Egnos
                      @Egnos maybe. but I don’t know if you ever constrained before. one of the commands I asked for results from was the memory free command
                      free -m
                      • E Offline
                        Egnos
                        free -m
                        lsb_release -a
                        uname -a
                        As requested:
                        pi@MagicMirror:~ $ lsb_release -a
                        No LSB modules are available.
                        Distributor ID:	Raspbian
                        Description:	Raspbian GNU/Linux 10 (buster)
                        Release:	10
                        Codename:	buster
                        pi@MagicMirror:~ $ uname -a
                        Linux MagicMirror 5.4.79-v7+ #1373 SMP Mon Nov 23 13:22:33 GMT 2020 armv7l GNU/Linux
                        Sometimes the message “mmap() failed: Cannot allocate memory” appears before the RAM saturation, no longer allowing MMM-GoogleAssistant to be able to launch searches on YouTube, etc …
                        Sometimes the error appears shortly after starting MM sometimes after a long time.
                        In the Sound page of @Bugsounet I read that the choice of the audio player could give these problems (“With HTML5, some device have some trouble with sound output (no sound output, only chime, mmap memory issue,…)”) but I have already done some tests and the only one that works is “mpg321”.
                        pi@MagicMirror:~ $ free -m
                                      total        used        free      shared  buff/cache   available
                        Mem:            924         452          95          43         376         373
                        Swap:            99           8          91
                        Mem:            924         455          58         253         411         165
                        Swap:            99          84          15
                        Mem:            924         462          48         254         413         157
                        Swap:            99          84          15
                        Mem:            924         463          48         253         413         157
                        Swap:            99          84          15
                        Mem:            924         465          35         263         424         145
                        Swap:            99          84          15
                        Mem:            924         466          47         249         410         158
                        Swap:            99          84          15
                        Mem:            924         470          43         249         410         153
                        Swap:            99          84          15
                        Mem:            924         471          31         261         422         142
                        Swap:            99          84          15
                        Mem:            924         468          53         248         403         157
                        Swap:            99          84          15
                        Mem:            924         467          56         246         400         161
                        Swap:            99          84          15
                        Mem:            924         465          55         249         403         160
                        Swap:            99          84          15
                        Mem:            924         467          32         270         425         136
                        Swap:            99          84          15
                        Mem:            924         468          31         270         424         136
                        Swap:            99          84          15
                        Mem:            924         469          30         270         424         135
                        Swap:            99          84          15
                        Mem:            924         469          29         271         426         134
                        Swap:            99          84          15
                        Mem:            924         469          31         272         423         133
                        Swap:            99          84          15
                        Mem:            924         471          47         254         405         149
                        Swap:            99          84          15
                        Mem:            924         473          44         254         406         147
                        Swap:            99          84          15
                        Swap:            99          84          15
                        Mem:            924         507          46         252         371         114
                        Swap:            99          96           3
                        Mem:            924         513          37         255         374         105
                        Swap:            99          96           3
                        Mem:            924         508          37         260         379         105
                        Swap:            99          96           3
                        Mem:            924         508          36         260         379         105
                        Swap:            99          96           3
                        Mem:            924         540          37         254         347          79
                        Swap:            99          99           0
                        Mem:            924         540          37         254         346          79
                        Swap:            99          99           0
                        Swap:            99          99           0
                        Mem:            924         528          48         254         348          91
                        Swap:            99          99           0
                        Mem:            924         455         120         248         348         170
                        Swap:            99          99           0
                        Mem:            924         465          60         269         398         141
                        Swap:            99          99           0
                        Mem:            924         465          60         268         398         141
                        Swap:            99          99           0
                        Mem:            924         494          35         253         394         122
                        Swap:            99          99           0
                        Mem:            924         495          54         251         374         127
                        Swap:            99          99           0
                        ^[[Ammap() failed: Impossibile allocare memoria
                        Would you have the patience to help me?
                        Many Thanks.
                          sdetweil @Egnos
                          @Egnos said in mmap() failed: Cannot allocate memory:
                          Swap: 99 99
                          u always have memory available, and never consume any swap space…
                          • E Offline
                            Egnos @sdetweil
                            Swap:            99          99           0
                            I see that all swap memory is finished … “Used =99 and free=0”.
                            I dont understand why it is already using swap memory if it is not out of RAM yet …
                            Why the swap memory always occupied?
                            Finished the task shouldn’t it free itself?
                            S 3 Replies Last reply Reply Quote 0
                              sdetweil @Egnos
                              @Egnos try this
                              for file in /proc/*/status ; do awk '/VmSwap|Name/{printf $2 " " $3}END{ print ""}' $file; done | sort -k 2 -n -r | less
                              should give a list of processes using swap, most to least
                                sdetweil @Egnos
                                @Egnos so, I would make the swap bigger just for for testing 1 gig
                                  sdetweil @Egnos
                                  @Egnos try this
                                  pm2 stop all
                                  export NODE_OPTIONS=--max_old_space_size=4096
                                  npm start
                                  u can add that export line to the installers/mm.sh
                                  if using pm2
