    mmap() failed: Cannot allocate memory
    15 Posts 2 Posters 6.2k Views 2 Watching
      sdetweil @Egnos
      @Egnos could be. the error is no memory
      • E
        Egnos
        @sdetweil said in mmap() failed: Cannot allocate memory:
        No memory do you mean RAM or SD memory?
          sdetweil @Egnos
          @Egnos ram technically heap.
          could be a bug in the module or a library it uses
          • E
            Egnos
            I found the follow procedure for prevent Raspberry Pi memory allocation failure.
            link
            1. All commands should be issued as root:
            sudo su
            1.5) If you have previously uninstalled dphys-swapfile:
            apt-get install dphys-swapfile
            1. Set the swap file size to double the amount on RAM:
            echo "CONF_SWAPSIZE=512" > /etc/dphys-swapfile
            dphys-swapfile setup
            If you have 512 MB RAM on the Pi then set swapsize to 1024.
            1. Enable swap
            dphys-swapfile swapon
            1. Exit the root shell
            exit
            And that’s it.
            Could be the solution to use the SWAP file?
              sdetweil @Egnos
              @Egnos maybe. but I don’t know if you ever constrained before. one of the commands I asked for results from was the memory free command
              free -m
              • E
                Egnos
                no idea… would take a bit of debugging
                in a terminal window do
                free -m
                lsb_release -a
                uname -a
                As requested:
                pi@MagicMirror:~ $ lsb_release -a
                No LSB modules are available.
                Distributor ID:	Raspbian
                Description:	Raspbian GNU/Linux 10 (buster)
                Release:	10
                Codename:	buster
                pi@MagicMirror:~ $ uname -a
                Linux MagicMirror 5.4.79-v7+ #1373 SMP Mon Nov 23 13:22:33 GMT 2020 armv7l GNU/Linux
                Sometimes the message “mmap() failed: Cannot allocate memory” appears before the RAM saturation, no longer allowing MMM-GoogleAssistant to be able to launch searches on YouTube, etc …
                Sometimes the error appears shortly after starting MM sometimes after a long time.
                In the Sound page of @Bugsounet I read that the choice of the audio player could give these problems (“With HTML5, some device have some trouble with sound output (no sound output, only chime, mmap memory issue,…)”) but I have already done some tests and the only one that works is “mpg321”.
                pi@MagicMirror:~ $ free -m
                              total        used        free      shared  buff/cache   available
                Mem:            924         452          95          43         376         373
                Swap:            99           8          91
                Mem:            924         455          58         253         411         165
                Swap:            99          84          15
                Mem:            924         462          48         254         413         157
                Swap:            99          84          15
                Mem:            924         463          48         253         413         157
                Swap:            99          84          15
                Mem:            924         465          35         263         424         145
                Swap:            99          84          15
                Mem:            924         466          47         249         410         158
                Swap:            99          84          15
                Mem:            924         470          43         249         410         153
                Swap:            99          84          15
                Mem:            924         471          31         261         422         142
                Swap:            99          84          15
                Mem:            924         468          53         248         403         157
                Swap:            99          84          15
                Mem:            924         467          56         246         400         161
                Swap:            99          84          15
                Mem:            924         465          55         249         403         160
                Swap:            99          84          15
                Mem:            924         467          32         270         425         136
                Swap:            99          84          15
                Mem:            924         468          31         270         424         136
                Swap:            99          84          15
                Mem:            924         469          30         270         424         135
                Swap:            99          84          15
                Mem:            924         469          29         271         426         134
                Swap:            99          84          15
                Mem:            924         469          31         272         423         133
                Swap:            99          84          15
                Mem:            924         471          47         254         405         149
                Swap:            99          84          15
                Mem:            924         473          44         254         406         147
                Swap:            99          84          15
                Swap:            99          84          15
                Mem:            924         507          46         252         371         114
                Swap:            99          96           3
                Mem:            924         513          37         255         374         105
                Swap:            99          96           3
                Mem:            924         508          37         260         379         105
                Swap:            99          96           3
                Mem:            924         508          36         260         379         105
                Swap:            99          96           3
                Mem:            924         540          37         254         347          79
                Swap:            99          99           0
                Mem:            924         540          37         254         346          79
                Swap:            99          99           0
                Swap:            99          99           0
                Mem:            924         528          48         254         348          91
                Swap:            99          99           0
                Mem:            924         455         120         248         348         170
                Swap:            99          99           0
                Mem:            924         465          60         269         398         141
                Swap:            99          99           0
                Mem:            924         465          60         268         398         141
                Swap:            99          99           0
                Mem:            924         494          35         253         394         122
                Swap:            99          99           0
                Mem:            924         495          54         251         374         127
                Swap:            99          99           0
                mmap() failed: Impossibile allocare memoria
                ^[[Ammap() failed: Impossibile allocare memoria
                Would you have the patience to help me?
                Many Thanks.
                  sdetweil @Egnos
                  @Egnos said in mmap() failed: Cannot allocate memory:
                  Swap: 99 99
                  u always have memory available, and never consume any swap space…
                  E 1 Reply Last reply
                  • E
                    Egnos @sdetweil
                    Swap:            99          99           0
                    I see that all swap memory is finished … “Used =99 and free=0”.
                    I dont understand why it is already using swap memory if it is not out of RAM yet …
                    Why the swap memory always occupied?
                    Finished the task shouldn’t it free itself?
                    S 3 Replies Last reply
                      sdetweil @Egnos
                      @Egnos try this
                      for file in /proc/*/status ; do awk '/VmSwap|Name/{printf $2 " " $3}END{ print ""}' $file; done | sort -k 2 -n -r | less
                      should give a list of processes using swap, most to least
                        sdetweil @Egnos
                        @Egnos so, I would make the swap bigger just for for testing 1 gig
                          sdetweil @Egnos
                          @Egnos try this
                          pm2 stop all
                          export NODE_OPTIONS=--max_old_space_size=4096
                          npm start
                          u can add that export line to the installers/mm.sh
                          if using pm2
