    Further personalization with Face-Reco
    16 Posts 3 Posters 3.9k Views 4 Watching
    • JerryPJ Offline
      JerryP @sdetweil
      ??? WHATEVER… it’s not my account…
      Luckily @macboy is getting the hint :) :)
        Macboy
        Just reposting the initial posts which I’ve deleted with the important info removed. (Thanks again for the heads up on what’s sensitive info and what’s not guys!)
        ------- Original post (in case anyone happens across this and doesn’t understand what my question/issue was) --------
        With my compliments.js per below and my config.js also per below, the Face Reco works. I’ll post a second reply here showing how I tried to change both of these files.
        Module.register("compliments", {
        	// Module config defaults.
        	defaults: {
        		compliments: {
        			anytime: ["Hey there, looking good!"],
        			morning: ["Good morning!", "Enjoy your day!", "Attack today!"],
        			afternoon: ["Hello, beauty!", "You look great!", "Looking good today!"],
        			evening: ["You nailed the day!", "What a great day!", "Hi family!"],
        			"....-01-01": ["Happy new year!"]
        		updateInterval: 80000,
        		remoteFile: null,
        		fadeSpeed: 4000,
        		morningStartTime: 3,
        		morningEndTime: 12,
        		afternoonStartTime: 12,
        		afternoonEndTime: 17,
        		random: true,
        		mockDate: null
        And my current config.js (the whole thing since I can’t figure out why it’s reverting to no Face Reco when I change it).
        var config = {
        	address: "localhost", 	// Address to listen on, can be:
        	port: 8080,
        	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
        	language: "en",
        	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
        	timeFormat: 24,
        	units: "metric",
            module: 'MMM-Face-Reco-DNN',
              // Logout 15 seconds after user was not detected any more
              // If they are detected within this period, the delay will start again
              logoutDelay: 15000,
              // How often the recognition starts in milliseconds
              // With a Raspberry Pi 3+ it works well every 2 seconds
              checkInterval: 2000,
              // Module set used for when there is no face detected ie no one is in front of the camera
              noFaceClass: 'noface',
              // Module set used for when there is an unknown/unrecognised face detected
              unknownClass: 'unknown',
              // Module set used for when there is a known/recognised face detected
              knownClass: 'known',
              // Module set used for strangers and if no user is detected
              defaultClass: 'default',
              // Set of modules which should be shown for any user ie when there is any face detected
              everyoneClass: 'everyone',
              // Set of modules that are always shown - show if there is a face or no face detected
              alwaysClass: 'always',
              // XML to recognize with haarcascade
              cascade: 'modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
              // Pre-encoded pickle with the faces
              encodings: 'modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
              // Use Raspberry Pi camera or another type
              // 1 = RasPi camera, 0 = other camera
              usePiCamera: 1,
              // If using another type of camera, you can choose
              // i.e. 0 = /dev/video0 or 'http://link.to/live'
              source: 0,
              // Rotate camera
              rotateCamera: 0,
              // Method of facial recognition
              // dnn = deep neural network, haar = haarcascade
              method: 'dnn',
              // Which face detection model to use
              // "hog" is less accurate but faster on CPUs
              // "cnn" is a more accurate deep-learning model which is GPU/CUDA accelerated
              detectionMethod: 'hog',
              // How long in milliseconds modules take to hide and show
              animationSpeed: 0,
              // Path to Python to run the face recognition
              // null or '' means default path
              pythonPath: null,
              // Should a welcome message be shown using the MagicMirror alerts module?
              welcomeMessage: true,
              // Capture new pictures of recognized people, if unknown we save it in folder "unknown"
              // So you can extend your dataset and retrain it afterwards for better recognitions
              extendDataset: false,
              // If extendDataset is true, you need to set the full path of the dataset
              dataset: 'modules/MMM-Face-Reco-DNN/dataset/',
              // How much distance between faces to consider it a match. Lower is more strict.
              tolerance: 0.6,
              // allow multiple concurrent user logins, 0=no, any other number is the maximum number of concurrent logins
              multiUser: 0,
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			classes: 'always'
        			header: "Coming Up...",
        			classes: 'anna julia kathy kelly',
        						symbol: "calendar-check",
        						url: "https://"					}
        			module: "compliments",
        			position: "lower_third",
        			classes: 'kelly'
        			module: "currentweather",
        				locationID: "5946768", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        				appid: "71ddee6bbdcfb25b97866519bc4a52bc"
        		module: "MMM-weatherforecast",
        		position: "top_right",	// This can be any of the regions.
        					// Best results in bottom_bar region due to horizontal default layout and icon sizes.
        			locationID: "5946768", //Location ID from http://openweathermap.org/help/city_list.txt
        			appid: "71ddee6bbdcfb25b97866519bc4a52bc" //openweathermap.org API key.
        			module: "newsfeed",
        			position: "bottom_bar",
        			classes: 'anna julia',
        				feeds: [
        						title: "According to CBC",
        						url: "https://rss.cbc.ca/lineup/canada-edmonton.xml"
        						title: "Upcoming Family Opportunities",
        						url: "https://www.raisingedmonton.com/feed/"
        				showSourceTitle: true,
        				showPublishDate: true,
        				broadcastNewsFeeds: true,
        				broadcastNewsUpdates: true
        		module: 'MMM-TweetsByTimelineOrList',
        		position: 'bottom_right',
        		classes: 'kathy kelly',
        		// visit the url below for the twitter keys/tokens
        		// https://dev.twitter.com/oauth/overview/application-owner-access-tokens
        			consumer_key: 'XXXXX',
        			consumer_secret: 'XXXXX',
        			access_token_key: 'XXXXX',
        			access_token_secret: 'XXXXX',
        		// set the username and either timeline or listname
        	        screenName: 'XXXXXXXXXXX',
        	        listToShow: 'TIMELINE',
                    module: 'default/MMM-Dad-Jokes',
                    position: 'bottom_bar', // Or wherever you want
                        updateInterval: 600000,
                        fadeSpeed: 4000
            module: 'default/MMM-ATM',
            position: 'bottom_bar',              // Works well anywhere
        	multipleChoice: "Yes",        // No = just the ? then the answer
        	useHeader: true,              // true if you want a header
        	header: "Feed your brain!",   // Any text you want
        	maxWidth: "1250px",             // Stretch or constrain according to region
          Macboy
          ----- Original Post #2 ------
          So I just removed the list of compliments from the compliments.js ‘defaults’ section and pasted the same to config.js as per below. First the new compliments.js
          	defaults: {
          		remoteFile: null,
          		fadeSpeed: 4000,
          		morningEndTime: 12,
          		random: true,
          		mockDate: null
          And the new config.js which disables the Face Reco and shows the compliments as undefined when the mirror loads.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
                logoutDelay: 15000,
                usePiCamera: 1,
                source: 0,
                // Rotate camera
                rotateCamera: 0,
                method: 'dnn',
                animationSpeed: 0,
                pythonPath: null,
                tolerance: 0.6,
                multiUser: 0,
          			module: "alert",
          			position: "top_bar"
          			module: "clock",
          			classes: 'always'
          						url: "https://"					}
          			classes: 'kelly',
          			module: "newsfeed",
          				feeds: [
                          fadeSpeed: 4000
            sdetweil @Macboy
            @Macboy cause u need to word compliments in the compliments config in config.js
              Macboy @JerryP
              @JerryP said in Further personalization with Face-Reco:
              I don’t want to come across as daft (now or in future posts) so forgive the clarification here. Is the hint I’m getting referring to “Don’t post sensitive info” or is this in reference to “I should read the docs”?
              Both equally important I agree.
              I’m new to this forum and through my searches over the past few weeks setting up my mirror I haven’t seen a lot of “Don’t annoy us, read the docs” posts like I’ve seen on other development type forums. But you guys could just have a kinder way about saying the same. I feel like for the most part I’ve followed the docs - hell…I’ve made it THIS far, right?
              When I set up the compliments module…well, when I customized it I should say, I really didn’t know what I was doing (this was early in the first mirror setup). I looked into config.js AND compliments.js and saw the default compliments there (in compliments.js). So, I edited them there and they worked. Now however when I try to set them up “correctly” in config.js it for some reason disables the Face-Reco setup. I’ll try the above formatting after work and post back if I still can’t figure out what I’ve done wrong to mess up the Face Recognition.
              I DO appreciate everyone’s help here, don’t think that I’m a “Log in and have people lay it all out for me” kind of guy. Many, many scratches to the head happen before I throw in the towel and ask for help - my wife will be the first to confirm that ; )
                Macboy
                It appears to be working now (snuck to the Pi on my lunch break). I left one compliment in the afternoon class of the defaults list in compliments.js and put one into the instance tagged with my name as the class in config.js using the proper formatting. I now see where I went wrong so thanks for the help. I’ll try making multiple instances in config.js with different users tagged in the classes.
