    Further personalization with Face-Reco
    16 Posts 3 Posters 5.3k Views 4 Watching
      sdetweil @Macboy
      @Macboy don’t need to duplicate module just create another instance set its classes and compliments in config.
        Macboy
        Thanks Sam. I’ll get to Googling how to do that. (New to this but loving the learning.)
          Macboy
          That was a quick find. Thanks for the direction. I had put my list of compliments into the compliments.js file, not in the instance in config.js.
          Edit - spoke too soon. If I try to move the compliments out of compliments.js (under the defaults) and into a config grouping as shown on the module use instructions in config.js not only does the mirror load up no longer using face recognition, but the compliments module shows as undefined. I’ll look into the forum use tools and see if I can figure out how to post the code here.
            Macboy
            JerryPJ 1 Reply Last reply
              Macboy
              • JerryPJ
                JerryP @Macboy
                @Macboy said in Further personalization with Face-Reco:
                MMM-TweetsByTimelineOrList
                Maybe i’t wise to remove the Ica url and your token licens code.
                so now I can check you agenda.
                S M 2 Replies Last reply
                  sdetweil @JerryP
                  @JerryP you are not following the doc.
                  module: "compliments",
                  classes:"......",
                  config:{
                     compliments:{
                  https://docs.magicmirror.builders/modules/compliments.html#configuration-options
                    Macboy @JerryP
                    @JerryP
                    Haha! Good to know! Thanks for pointing that out to me. It’s a pretty dormant Twitter account but I guess one never knows how that could be used.
                      Macboy
                      @michmich @paviro
                      I’m unable to edit the posts above with my wife’s tokens because too much time has passed since I posted. Do one of you have the ability to either redact that portion of the code snippets (the TimelineOrList sections) in both posts above?
                      Possibly harmless to have that info out in public but someone could maliciously use her account for evil I guess. If the posts need to be removed that is okay as well. And if there is a method available to me to pull the posts or edit them I’m happy to do so - just let me know how. I’ll be more alert next time I start posting code. Funny enough I DID take a quick scan making sure I wasn’t posting SSIDs and passwords…haha
                      If anyone else knows how I can change that up just let me know.
                      • JerryPJ
                        JerryP @sdetweil
                        ??? WHATEVER… it’s not my account…
                        Luckily @macboy is getting the hint :) :)
                        M 1 Reply Last reply
                          Macboy
                          Just reposting the initial posts which I’ve deleted with the important info removed. (Thanks again for the heads up on what’s sensitive info and what’s not guys!)
                          ------- Original post (in case anyone happens across this and doesn’t understand what my question/issue was) --------
                          With my compliments.js per below and my config.js also per below, the Face Reco works. I’ll post a second reply here showing how I tried to change both of these files.
                          Module.register("compliments", {
                          	// Module config defaults.
                          	defaults: {
                          		compliments: {
                          			anytime: ["Hey there, looking good!"],
                          			morning: ["Good morning!", "Enjoy your day!", "Attack today!"],
                          			afternoon: ["Hello, beauty!", "You look great!", "Looking good today!"],
                          			evening: ["You nailed the day!", "What a great day!", "Hi family!"],
                          			"....-01-01": ["Happy new year!"]
                          		updateInterval: 80000,
                          		remoteFile: null,
                          		fadeSpeed: 4000,
                          		morningStartTime: 3,
                          		morningEndTime: 12,
                          		afternoonStartTime: 12,
                          		afternoonEndTime: 17,
                          		random: true,
                          		mockDate: null
                          And my current config.js (the whole thing since I can’t figure out why it’s reverting to no Face Reco when I change it).
                          var config = {
                          	address: "localhost", 	// Address to listen on, can be:
                          	port: 8080,
                          	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                          	language: "en",
                          	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                          	timeFormat: 24,
                          	units: "metric",
                              module: 'MMM-Face-Reco-DNN',
                                // Logout 15 seconds after user was not detected any more
                                // If they are detected within this period, the delay will start again
                                logoutDelay: 15000,
                                // How often the recognition starts in milliseconds
                                // With a Raspberry Pi 3+ it works well every 2 seconds
                                checkInterval: 2000,
                                // Module set used for when there is no face detected ie no one is in front of the camera
                                noFaceClass: 'noface',
                                // Module set used for when there is an unknown/unrecognised face detected
                                unknownClass: 'unknown',
                                // Module set used for when there is a known/recognised face detected
                                knownClass: 'known',
                                // Module set used for strangers and if no user is detected
                                defaultClass: 'default',
                                // Set of modules which should be shown for any user ie when there is any face detected
                                everyoneClass: 'everyone',
                                // Set of modules that are always shown - show if there is a face or no face detected
                                alwaysClass: 'always',
                                // XML to recognize with haarcascade
                                cascade: 'modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
                                // Pre-encoded pickle with the faces
                                encodings: 'modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
                                // Use Raspberry Pi camera or another type
                                // 1 = RasPi camera, 0 = other camera
                                usePiCamera: 1,
                                // If using another type of camera, you can choose
                                // i.e. 0 = /dev/video0 or 'http://link.to/live'
                                source: 0,
                                // Rotate camera
                                rotateCamera: 0,
                                // Method of facial recognition
                                // dnn = deep neural network, haar = haarcascade
                                method: 'dnn',
                                // Which face detection model to use
                                // "hog" is less accurate but faster on CPUs
                                // "cnn" is a more accurate deep-learning model which is GPU/CUDA accelerated
                                detectionMethod: 'hog',
                                // How long in milliseconds modules take to hide and show
                                animationSpeed: 0,
                                // Path to Python to run the face recognition
                                // null or '' means default path
                                pythonPath: null,
                                // Should a welcome message be shown using the MagicMirror alerts module?
                                welcomeMessage: true,
                                // Capture new pictures of recognized people, if unknown we save it in folder "unknown"
                                // So you can extend your dataset and retrain it afterwards for better recognitions
                                extendDataset: false,
                                // If extendDataset is true, you need to set the full path of the dataset
                                dataset: 'modules/MMM-Face-Reco-DNN/dataset/',
                                // How much distance between faces to consider it a match. Lower is more strict.
                                tolerance: 0.6,
                                // allow multiple concurrent user logins, 0=no, any other number is the maximum number of concurrent logins
                                multiUser: 0,
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			classes: 'always'
                          			header: "Coming Up...",
                          			classes: 'anna julia kathy kelly',
                          						symbol: "calendar-check",
                          						url: "https://"					}
                          			position: "lower_third",
                          			classes: 'kelly'
                          			module: "currentweather",
                          				locationID: "5946768", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                          				appid: "71ddee6bbdcfb25b97866519bc4a52bc"
                          		module: "MMM-weatherforecast",
                          		position: "top_right",	// This can be any of the regions.
                          					// Best results in bottom_bar region due to horizontal default layout and icon sizes.
                          			locationID: "5946768", //Location ID from http://openweathermap.org/help/city_list.txt
                          			appid: "71ddee6bbdcfb25b97866519bc4a52bc" //openweathermap.org API key.
                          			module: "newsfeed",
                          			position: "bottom_bar",
                          			classes: 'anna julia',
                          				feeds: [
                          						title: "According to CBC",
                          						url: "https://rss.cbc.ca/lineup/canada-edmonton.xml"
                          						title: "Upcoming Family Opportunities",
                          						url: "https://www.raisingedmonton.com/feed/"
                          				showSourceTitle: true,
                          				showPublishDate: true,
                          				broadcastNewsFeeds: true,
                          				broadcastNewsUpdates: true
                          		module: 'MMM-TweetsByTimelineOrList',
                          		position: 'bottom_right',
                          		classes: 'kathy kelly',
                          		// visit the url below for the twitter keys/tokens
                          		// https://dev.twitter.com/oauth/overview/application-owner-access-tokens
                          			consumer_key: 'XXXXX',
                          			consumer_secret: 'XXXXX',
                          			access_token_key: 'XXXXX',
                          			access_token_secret: 'XXXXX',
                          		// set the username and either timeline or listname
                          	        screenName: 'XXXXXXXXXXX',
                          	        listToShow: 'TIMELINE',
                                      module: 'default/MMM-Dad-Jokes',
                                      position: 'bottom_bar', // Or wherever you want
                                          updateInterval: 600000,
                                          fadeSpeed: 4000
                              module: 'default/MMM-ATM',
                              position: 'bottom_bar',              // Works well anywhere
                          	multipleChoice: "Yes",        // No = just the ? then the answer
                          	useHeader: true,              // true if you want a header
                          	header: "Feed your brain!",   // Any text you want
                          	maxWidth: "1250px",             // Stretch or constrain according to region
                            Macboy
                            ----- Original Post #2 ------
                            So I just removed the list of compliments from the compliments.js ‘defaults’ section and pasted the same to config.js as per below. First the new compliments.js
                            	defaults: {
                            		remoteFile: null,
                            		fadeSpeed: 4000,
                            		morningEndTime: 12,
                            		random: true,
                            		mockDate: null
                            And the new config.js which disables the Face Reco and shows the compliments as undefined when the mirror loads.
                            var config = {
                            	port: 8080,
                            	language: "en",
                            	timeFormat: 24,
                            	units: "metric",
                                  logoutDelay: 15000,
                                  usePiCamera: 1,
                                  source: 0,
                                  // Rotate camera
                                  rotateCamera: 0,
                                  method: 'dnn',
                                  animationSpeed: 0,
                                  pythonPath: null,
                                  tolerance: 0.6,
                                  multiUser: 0,
                            			module: "alert",
                            			position: "top_bar"
                            			module: "clock",
                            			classes: 'always'
                            						url: "https://"					}
                            			classes: 'kelly',
                            			module: "newsfeed",
                            				feeds: [
                                            fadeSpeed: 4000
                              sdetweil @Macboy
                              @Macboy cause u need to word compliments in the compliments config in config.js
                                Macboy @JerryP
                                @JerryP said in Further personalization with Face-Reco:
                                I don’t want to come across as daft (now or in future posts) so forgive the clarification here. Is the hint I’m getting referring to “Don’t post sensitive info” or is this in reference to “I should read the docs”?
                                Both equally important I agree.
                                I’m new to this forum and through my searches over the past few weeks setting up my mirror I haven’t seen a lot of “Don’t annoy us, read the docs” posts like I’ve seen on other development type forums. But you guys could just have a kinder way about saying the same. I feel like for the most part I’ve followed the docs - hell…I’ve made it THIS far, right?
                                When I set up the compliments module…well, when I customized it I should say, I really didn’t know what I was doing (this was early in the first mirror setup). I looked into config.js AND compliments.js and saw the default compliments there (in compliments.js). So, I edited them there and they worked. Now however when I try to set them up “correctly” in config.js it for some reason disables the Face-Reco setup. I’ll try the above formatting after work and post back if I still can’t figure out what I’ve done wrong to mess up the Face Recognition.
                                I DO appreciate everyone’s help here, don’t think that I’m a “Log in and have people lay it all out for me” kind of guy. Many, many scratches to the head happen before I throw in the towel and ask for help - my wife will be the first to confirm that ; )
                                  Macboy
                                  It appears to be working now (snuck to the Pi on my lunch break). I left one compliment in the afternoon class of the defaults list in compliments.js and put one into the instance tagged with my name as the class in config.js using the proper formatting. I now see where I went wrong so thanks for the help. I’ll try making multiple instances in config.js with different users tagged in the classes.
