Integrating an npm module that uses import
i helped someone with a similar problem but the n module was wrutten in typescript and down compiled to js
@sdetweil @strawberry-3-141
I can’t get it working.
node 14.15 installed.When I
requirethe “picnic-api” npm module the usual way I get the error message inside the "picnic-api module.import axios from "axios"; ^^^^^^ SyntaxError: Cannot use import statement outside a moduleWhen I do the
importlike described in the readme the error originates in my node_helper.jsimport PicnicClient, { CountryCodes, ImageSizes, HttpMethods } from "picnic-api"; ^^^^^^ SyntaxError: Cannot use import statement outside a moduleI’m lost. At least the environment of the picnic-api module should be a “pure node” environment, why does the
importnot work at least in that module?Changing the index.js inside picnic-api to an .mjs does not help.
Any more ideas?
@lavolp3 i do not know. i consider myself a node rookie, and a typescript noobie.
because i am away from my systems i am unable to try different solutions… at least a few more weeks
if u try w
node serverOnlydoes it make a difference?
there the node engine is running the code, vs the engine thru electron…
