    Integrating an npm module that uses import
    13 Posts 4 Posters 5.3k Views 4 Watching
      sdetweil @lavolp3
      @lavolp3 yiu can also use
      const ax = require('axios')
      in node_helper.js
      after npm install axios
      • lavolp3L
        @sdetweil that’s not sufficient. There are two more modules imported by the picnic-api module. I could require them all in node_helper but that looks too of much a workaround for me. There should be another way.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          sdetweil @lavolp3
          @lavolp3 sometimes u get to do things that arent perfect. but get to move on.
          • karsten13K
            karsten13 @lavolp3
            @lavolp3
            • rename node_helper.js to node_helper.mjs
            worked in my test (did not do anything with the imported axios, but mm starts).
              sdetweil @karsten13
              @karsten13 was node_helper loaded? i doubt it. its optional. so this doesnt help
              • karsten13K
                karsten13 @sdetweil
                @sdetweil no :crying_face:
                may using esm library is one approach as described e.g. here https://blog.logrocket.com/how-to-use-ecmascript-modules-with-node-js/
                  sdetweil @karsten13
                  @karsten13 in node… but we have a custom environment, that is not node pure…
                    i helped someone with a similar problem but the n module was wrutten in typescript and down compiled to js
                    https://github.com/Mitica/public-holidays-js
                    • lavolp3L
                      @sdetweil @strawberry-3-141
                      I can’t get it working.
                      node 14.15 installed.
                      When I require the “picnic-api” npm module the usual way I get the error message inside the "picnic-api module.
                      import axios from "axios";
                      SyntaxError: Cannot use import statement outside a module
                      When I do the import like described in the readme the error originates in my node_helper.js
                              import PicnicClient, { CountryCodes, ImageSizes, HttpMethods } from "picnic-api";
                      I’m lost. At least the environment of the picnic-api module should be a “pure node” environment, why does the import not work at least in that module?
                      Changing the index.js inside picnic-api to an .mjs does not help.
                      Any more ideas?
                        sdetweil @lavolp3
                        @lavolp3 i do not know. i consider myself a node rookie, and a typescript noobie.
                        because i am away from my systems i am unable to try different solutions… at least a few more weeks
                        if u try w
                        node serverOnly
                        does it make a difference?
                        there the node engine is running the code, vs the engine thru electron…
