    Integrating an npm module that uses import
    13 Posts 4 Posters 4.7k Views 4 Watching
    • lavolp3L Offline
      @sdetweil that’s not sufficient. There are two more modules imported by the picnic-api module. I could require them all in node_helper but that looks too of much a workaround for me. There should be another way.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        sdetweil @lavolp3
        @lavolp3 sometimes u get to do things that arent perfect. but get to move on.
        • karsten13K Offline
          karsten13 @lavolp3
          @lavolp3
          • rename node_helper.js to node_helper.mjs
          worked in my test (did not do anything with the imported axios, but mm starts).
            sdetweil @karsten13
            @karsten13 was node_helper loaded? i doubt it. its optional. so this doesnt help
              karsten13 @sdetweil
              @sdetweil no :crying_face:
              may using esm library is one approach as described e.g. here https://blog.logrocket.com/how-to-use-ecmascript-modules-with-node-js/
                sdetweil @karsten13
                @karsten13 in node… but we have a custom environment, that is not node pure…
                  i helped someone with a similar problem but the n module was wrutten in typescript and down compiled to js
                  https://github.com/Mitica/public-holidays-js
                  • lavolp3L Offline
                    @sdetweil @strawberry-3-141
                    I can’t get it working.
                    node 14.15 installed.
                    When I require the “picnic-api” npm module the usual way I get the error message inside the "picnic-api module.
                    import axios from "axios";
                    SyntaxError: Cannot use import statement outside a module
                    When I do the import like described in the readme the error originates in my node_helper.js
                            import PicnicClient, { CountryCodes, ImageSizes, HttpMethods } from "picnic-api";
                    I’m lost. At least the environment of the picnic-api module should be a “pure node” environment, why does the import not work at least in that module?
                    Changing the index.js inside picnic-api to an .mjs does not help.
                    Any more ideas?
                      sdetweil @lavolp3
                      @lavolp3 i do not know. i consider myself a node rookie, and a typescript noobie.
                      because i am away from my systems i am unable to try different solutions… at least a few more weeks
                      if u try w
                      node serverOnly
                      does it make a difference?
                      there the node engine is running the code, vs the engine thru electron…
