Integrating an npm module that uses import
13 Posts 4 Posters 4.3k Views 4 Watching
  • L Offline
    lavolp3 Module Developer
    HI all,
    I am trying to write a module around the npm module picnic-api that uses the import function instead of require
    import axios from "axios";
    This does not work within the Magicmirror environment, I get an error message when I start the mirror.
    [13.02.2021 07:21.43.938] [ERROR] /home/pi/MagicMirror/modules/MMM-Picnic/node_modules/picnic-api/index.js:1
    SyntaxError: Cannot use import statement outside a module
    Does anyone have a solution for me?
    Is there a way to use it or do I need to rewrite the npm module?
    How to troubleshoot modules
    MMM-soccer v2, MMM-AVStock
    S 1 Reply Last reply Feb 13, 2021, 7:14 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @lavolp3
      @lavolp3 which version of nodejs are you running? import is a feature of es6 modules. You can try to enable it like this https://stackoverflow.com/a/45854500
      L 1 Reply Last reply Feb 13, 2021, 12:14 PM Reply Quote 1
      • L Offline
        lavolp3 Module Developer @strawberry 3.141
        @strawberry-3-141 said in Integrating an npm module that uses import:
        Thanks for the tip. Upgraded to node.js 14.15 but did not work yet.
        Seeing "type": "module in my package.json also did not help.
        I will have to have a closer look at the link
        S K 2 Replies Last reply Feb 13, 2021, 1:19 PM Reply Quote 0
          sdetweil @lavolp3
          @lavolp3 yiu can also use
          const ax = require('axios')
          in node_helper.js
          after npm install axios
          L 1 Reply Last reply Feb 13, 2021, 2:15 PM Reply Quote 0
          • L Offline
            @sdetweil that’s not sufficient. There are two more modules imported by the picnic-api module. I could require them all in node_helper but that looks too of much a workaround for me. There should be another way.
            S 1 Reply Last reply Feb 13, 2021, 2:46 PM Reply Quote 0
              sdetweil @lavolp3
              @lavolp3 sometimes u get to do things that arent perfect. but get to move on.
              • K Offline
                karsten13 @lavolp3
                @lavolp3
                • rename node_helper.js to node_helper.mjs
                worked in my test (did not do anything with the imported axios, but mm starts).
                S 1 Reply Last reply Feb 13, 2021, 7:39 PM Reply Quote 0
                  sdetweil @karsten13
                  @karsten13 was node_helper loaded? i doubt it. its optional. so this doesnt help
                  K 1 Reply Last reply Feb 13, 2021, 8:06 PM Reply Quote 0
                  • K Offline
                    karsten13 @sdetweil
                    @sdetweil no :crying_face:
                    may using esm library is one approach as described e.g. here https://blog.logrocket.com/how-to-use-ecmascript-modules-with-node-js/
                    S 1 Reply Last reply Feb 13, 2021, 8:15 PM Reply Quote 0
                      sdetweil @karsten13
                      @karsten13 in node… but we have a custom environment, that is not node pure…
