    MagicMirror installation electron warning
    3 Posts 2 Posters 942 Views 2 Watching
    • R
      renevandenbroek
      New Raspian pi4 with 1 Gb
      New OS installed
      Followed the instructions for installing MM
      When I start MM I get the following warning.
      [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
      Is this “normal”? is it " problem" ?Should I solve it? If so, how should i solve it?
        sdetweil @renevandenbroek
        @renevandenbroek this is normal currently. no problems caused by this
        • R
          renevandenbroek
          Thank you for your quick response
