    Problem with electron
    2 Posts 2 Posters 404 Views 2 Watching
    • E Offline
      Ex0HanZ
      Hello everyone,
      I’m trying to install MM on a normal desktop pc. I successfully installed Raspbian Desktop and downloaded MM + Node + pm2. Unfortunately when the system boots up, the MM screen shows up for 10-15 seconds then disappears and the normal Raspbian Desktop shows up.
      In terminal
      when I go to “cd MagicMirror/”
      Then I type “pm2 stop all”
      followed by "npm start:
      The result is:
      micmirror@2.14.0 start
      DISPLAY="${DISPLAY:=0}" ./node_modules/.bin/.electron js/electron.js
      sh:1 ./node_modules/.bin/electron: not found
      Can it be a problem because the PC is not a RaspberryPi? Or there is something else incompatible with the PC and Electron?
      Thank you in advance!
        sdetweil @Ex0HanZ
        @ex0hanz its not incompatible with.
        ive run that same combo without problem
        can u look at node_modules/.bin and see whats there.
        how did u install, git clone & npm install? or my automated script?
        if u do
        cd ~/MagicMirror
        npm start
        does mm run?
        is the user issuing pm2 resurect the same that did the pm2 save? and NOT root or sudo
