    Hardware recommendation
    hardwarescreenrecommandation
    2 Posts 2 Posters 1.6k Views 2 Watching
    • G
      Gbarranco
      Hello !
      I’m a newbie, I want to create a magic mirror but I’m a bit lost 🤔
      What screen do you recommend for a magic mirror ? There will be no mic available on it at first.
      By the way I’m from France and I would like to be able to order from here 😊
      Thank you very much
      • BKeyportB
        BKeyport Module Developer @Gbarranco
        @gbarranco Any monitor will work that has HDMI input. Here’s the trick though. if you’re gonna put it in/on a wall, use a monitor that has it’s ports pointing down, not out of the back. Make sure if you’re going to put it behind mirror glass that it’s flat - you don’t want a curve on it so it can sit flat against your external glass.
        I personally use a monitor like this one: https://www.amazon.com/Dell-Ultrasharp-U2719DX-2560x1440-Resolution/dp/B07KGR784M/ref=sr_1_4?dchild=1&keywords=edge+to+edge+monitor&qid=1615315119&sr=8-4
        Notice how the image is edge to edge, that way I can take off the frame and have almost all the monitor used.
