    Need help resizing in vertical orientation
    36 Posts 3 Posters 12.4k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer @Matthewlawson3
      If you wanna use the entire screen - in custom.css add:
      /* Use the entire screen */
      body {
      	margin: 0px;
      	height: 100vh;
      	width: 100vw;
      Don’t copy main.css into custom and start there - it’s a bad idea - just fiddle with the tags you wanna adjust. The mirror loads main.css, then every module’s CSS file, then custom.css and css will add your rules to the tag.
        sdetweil @BKeyport
        @bkeyport make sure if u change body like that, to fix the fullscreen definition which does a negative value to reverse the margin value coded in body.
        also, copying main was because we recommend NOT changing values there
          Matthewlawson3 @sdetweil
          @sdetweil okay. I’ve never modified anything CSS. Sounds like I am modifying code like that that is used for a webpage. A few questions…
          Where is the main.css and custom.css located?
          You are saying make a copy of the original main.css and I then modify the original main.css? I assume if something goes wrong that I can then copy back in place the copy of the original main.css to get everything back to normal.
          What do I use custom.css for?
          Thanks and forgive my ignorance on this!
          S 3 Replies Last reply Reply Quote 0
            sdetweil @Matthewlawson3
            @matthewlawson3 the css files are in the MagicMirror/css folder
            MagicMirror is indeed a webpage, called a Single Page Application
            because CSS supports overriding (replacing) styles previously defined
            the order of processsing is
            main.css
            any module provided classes/styles, thru the getStyles() method
            custom.css
            this way custom.css can change anything defined before
              @matthewlawson3 I was suggesting NEVER to modify main.css
              so, if u follow that rule, you need custom.css to contain what is in main.css for testing
                @matthewlawson3 see this topic
                https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1616334901530
                  @sdetweil so I just copy the contents of main.css into a new file called custom.css? Then I modify custom.css and that should show when I run the MM? Or does that custom.css have to be renamed to main.css and the original main.css renamed to something else while testing?
                    @matthewlawson3 do this
                    cd ~/MagicMirror/css
                    cp main.css custom.css
                    edit custom.css and change
                    body {
                      margin: 60px;
                      position: absolute;
                      height: calc(100% - 120px);
                      width: calc(100% - 120px);
                      background: green;                                     <- this line
                      color: #aaa;
                      font-family: "Roboto Condensed", sans-serif;
                      font-weight: 400;
                      font-size: 2em;
                      line-height: 1.5em;
                      -webkit-font-smoothing: antialiased;
                    start mm
                    and u should see this
                    now you can see the border around the main area, where all the modules are placed
                      @Matthewlawson3
                      and if u set the background-color for date, time, and calendar
                      .calendar {
                      	background-color: blue;
                      .date {
                      	background-color: red;
                      .time {
                      	background-color: pink;
                      you’ll see this
                        @sdetweil Thank you. So when I can see the borders, I would assume I have to adjust the border size and make it smaller?
                        Below are some pictures of the MMM Tools issue and the BibleGateway issue where they are invading the space of the other modules. I need MMM Tools to fill that gap on the left and the BibleGateway module to get back to the right side.
                        alt text
                        alt text
                        • 3 / 4
