    Powering my monitor
    3 Posts 4 Posters 917 Views 4 Watching
    • F Offline
      Flavito
      Hello guys,
      So here is my issue:
      I got a monitor (LM215WF4-TLE7) without any cables.
      After some googling, I can’t / I’m struggling to find how I can power it and plug an input.
      Do you know where I can find the right control board if needed?
      “needed” because I was wondering if we could just plug the connector (that I have to find) right into the raspberry but I’ve never experienced any of this before. That’s why I’m looking for advice that could help …
      Thanks for reading and have a nice one !
      :beaming_face_with_smiling_eyes:
      Flavito
        MadScientist @Flavito
        @flavito You posted the model type of the LCD panel. So I assume you don’t have a complete monitor but just the naked panel. Hence your question about connecting it to the pi.
        What you need is a LCD controller board. I wrote a lot about those in this forum already and I don’t want to repeat myself all the time. So have a look here and here. Maybe use the forum search. You should find all the information you need.
        What I can tell you is that your panel is 21.5 inch, FullHD (1920x1080) and it has a 30-pin 2-Channel, 8-bit interface.
        You’ll find solutions as cheap as 3-4€ with a bit of hands-on work, 10€ for plug’n’play but a relay is needed if you want to use a PIR-sensor, or 30€ for a board with the needed firmware pre-installed. They all have pros (e.g. price) and cons (custom wiring).
        Read a bit and if you have further questions you just ask again. Usually I look at the forum daily or at least every two days.
        Disclaimer: I am with no means an expert here. I just went through the same research when I build my mirror.
        C 1 Reply Last reply Reply Quote 1
        • C Offline
          Claud Rea @MadScientist
          @madscientist said in Powering my monitor:
          @flavito five nights at freddy’s You posted the model type of the LCD panel. So I assume you don’t have a complete monitor but just the naked panel. Hence your question about connecting it to the pi.
          i got it, thank you for the explanation.
