    MMM-videoplayer
    5 Posts 2 Posters 1.5k Views 1 Watching
      Sceetch
      Hi guys,
      im using the MMM-videoplayer module on a 50 inch TV.
      Does anybody has a proposal of the properties for the played .mp4 file?
      currently im using a file with 400mb and a length of 9 min.
      witdth = 1280
      heigth = 720
      Date rate = 6006 kBit/s
      total rate = 6086 kBit/s
      single bit rate = 25 pic/sec
      if i play this video, the picture jerks and it doesn’t look smooth.
      in which format i have to convert the video for an acceptable result?
      Thanks in advance
      SnilleS 1 Reply Last reply Reply Quote 0
      • SnilleS Offline
        Snille Module Developer @Sceetch
        @sceetch Hi! Are you running on a RPi? Not sure if it can handle the load of playing a 720p in the webbrowser (that is used for the mirror)… A RPi 4 may be able to? Not sure… I moved my mirror over to an Intel NUC to be able to play 1080p in full screen… :)
        If you cant find it, make it and share it
        MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
          Sceetch @Snille
          @snille
          thx for reply,
          the mirror is running on a RPI 4.
          It seems that this RPI is to weak for this requierement.
          a NUC is in this case, for sure, the right one :-)
          I have to create some different versions of the video & properties.
          This takes a while to convert step by step the video
            Sceetch @Snille
            @snille
            Hey snille,
            what are your specifications about your NUC?
            Im thinking about to buy one.
            Its seems that the PI4 is not able to represent videos in full screen with acceptable quality :-(
            • SnilleS Offline
              @sceetch Hi, This is what I’m running with 8 gigs of ram and an SSD. :)
