MMM-Carousel Hide Mousecursor
it is possible to hide the Mousecursor when the MMM-Carousel is installed?
i changed from MMM-Pages + Page Indicator to MMM-Carousel because its faster and works a little bit better for me. But after the change there is a littel hand as a mousecursor? I want to hide oder remove this. The courser is only displayed when i use the Pageinationbuttons or the Slidebuttons from the MMM-Carousel modul?
Greetings Torsten
@foxy25
out of interest what device are you running MMM-Carousel on as I was just about to install MMM-Pages + Page Indicator until I read you comment. -
HI
im running a Raspi 4B 8GB with Raspian Buster.
Maybe there is an other Issue with the modul: sometimes the screensaver comes up and lock the screen with a password prompt?
Greetings Torsten
@foxy25
Given your hardware I’d say you’re platform is sound.Questions:
Have you removed the MMM-pages & MMM-page-indicator folders in the ~/MagicMirror/modules folder.Do you have a backup of the original config.js file (~/MagicMirror/config/config.js)
Possible Test Solution:
If you had a copy of the original config.js file and did a backup or rename of your current config.js file you could just add the MMM-Carousel settings into the original or a vanilla config.js file and ‘pm2 restart MagicMirror’ to see if you get the same result.As a way of testing its a quick way to test the module and/or MagicMirror.
Hi @arus,
no, i dont have the mmm-pages and page-indicator folder in /MagicMirror/modules removed.
I only comment the modules it in the config.js out.
ok, when i have a littel more time this weekend i test it out.
Thank you for your hints.
I get in touch here, wen im finish with the test.
Greetings Torsten
