    MMM- Remote Control help
    16 Posts 4 Posters 4.9k Views 4 Watching
    • N Offline
      Nneuland @sdetweil
      Thanks Sam. Oddly turning off firewall is yielding the same results.
      Not sure the problem…
        sdetweil @Nneuland
        @nneuland had someone the other day have pi on guest wifi while phone was on family wifi…
        • N Offline
          Nneuland @sdetweil
          Nailed it! That was exactly the issue.
          Thank you Sam. SOLVED
          C D 2 Replies Last reply Reply Quote 1
          • C Offline
            CheapDad @Nneuland
            :grinning_face_with_sweat:
              DigiDadbod @Nneuland
              @nneuland just want to let you know; depending on how good your router is, you should be able to get it set up on a separate IOT network if desired. I forget exactly how I set mine up but it was either by allowing specific IP addresses to talk to each other one way, or a combo of that and enebling mDNS of some sorts (which is something I think you have to enable for things like Google speaker on an adjacent local network). Obviously, you will find better info on a forum dedicated to your router…
              • N Offline
                Nneuland @DigiDadbod
                @digidadbod
                That’s great. Thank you for the tip
