    MMM- Remote Control help
    16 Posts 4 Posters 6.6k Views 4 Watching
      sdetweil @Nneuland
      @nneuland 1st let’s take everything out
      N 1 Reply Last reply
      • N
        Nneuland @sdetweil
        Thanks for the help. []
        This site can’t be reached192.168.xxx.xxx took too long to respond.
        Try:
        Checking the connection
        Checking the proxy and the firewall
        Running Windows Network Diagnostics
        ERR_CONNECTION_TIMED_OUT
        S N 2 Replies Last reply
          sdetweil @Nneuland
          @nneuland can u connect to mm
          http://ip:8080
          • N
            Nneuland @Nneuland
            @nneuland sadly no
            This site can’t be reachedCheck if there is a typo in ip.
            If spelling is correct, try running Windows Network Diagnostics.
            DNS_PROBE_FINISHED_NXDOMAIN
              sdetweil @Nneuland
              @nneuland ok, so it’s a networking problem
              u said windows… I always turn off the firewall for a while
              • N
                Nneuland @sdetweil
                Thanks Sam. Oddly turning off firewall is yielding the same results.
                Not sure the problem…
                  sdetweil @Nneuland
                  @nneuland had someone the other day have pi on guest wifi while phone was on family wifi…
                  • N
                    Nneuland @sdetweil
                    Nailed it! That was exactly the issue.
                    Thank you Sam. SOLVED
                    C D 2 Replies Last reply
                      CheapDad @Nneuland
                      :grinning_face_with_sweat:
                        DigiDadbod @Nneuland
                        @nneuland just want to let you know; depending on how good your router is, you should be able to get it set up on a separate IOT network if desired. I forget exactly how I set mine up but it was either by allowing specific IP addresses to talk to each other one way, or a combo of that and enebling mDNS of some sorts (which is something I think you have to enable for things like Google speaker on an adjacent local network). Obviously, you will find better info on a forum dedicated to your router…
                        • N
                          Nneuland @DigiDadbod
                          @digidadbod
                          That’s great. Thank you for the tip
