    MMM- Remote Control help
    16 Posts 4 Posters 6.0k Views 4 Watching
    • N Offline
      Nneuland
      Can anyone explain the ip modifications needed to the config file for the Remote Control module?
        sdetweil @Nneuland
        @nneuland the address and ipWhilelist fields control what clients can connect to MagicMirror
        address set to “localhost”, means only apps INSIDE the same machine can connect
        changing to “0.0.0.0” (all adapters) means SOME systems outside the MM machine can connect,
        and ipWhitelist give a list of address masks to test if those systems are allowed
        for easy access , and no security for anyone on your local lan/wifi), address:“0.0.0.0” and ipWhiltelist:[] will allow anyone on your lan/wifi to connect to the MagicMirror application
        • N Offline
          Nneuland @sdetweil
          Thank you for the reply. After adjusting the address to “0.0.0.0” and adding my IP, I’m in a holding pattern of blank screen and curser, and no connection to the http://192.168.xxx.xxx:8080/remote.html website.
          “This site can’t be reached”
            sdetweil @Nneuland
            @nneuland did u remove everything from ipWhitelist?
            • N Offline
              Nneuland @sdetweil
              This is what have in my ipWhitelist
              ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “ffff:192.168.XXX.XXX”], // Set [] to allow all IP addresses
              I have xxx’d my actual ip address.
                sdetweil @Nneuland
                @nneuland 1st let’s take everything out
                • N Offline
                  Nneuland @sdetweil
                  Thanks for the help. []
                  This site can’t be reached192.168.xxx.xxx took too long to respond.
                  Try:
                  Checking the connection
                  Checking the proxy and the firewall
                  Running Windows Network Diagnostics
                  ERR_CONNECTION_TIMED_OUT
                  S N 2 Replies Last reply Reply Quote 0
                    sdetweil @Nneuland
                    @nneuland can u connect to mm
                    http://ip:8080
                    • N Offline
                      Nneuland @Nneuland
                      @nneuland sadly no
                      This site can’t be reachedCheck if there is a typo in ip.
                      If spelling is correct, try running Windows Network Diagnostics.
                      DNS_PROBE_FINISHED_NXDOMAIN
                        sdetweil @Nneuland
                        @nneuland ok, so it’s a networking problem
                        u said windows… I always turn off the firewall for a while
                        • N Offline
                          Nneuland @sdetweil
                          Thanks Sam. Oddly turning off firewall is yielding the same results.
                          Not sure the problem…
                            sdetweil @Nneuland
                            @nneuland had someone the other day have pi on guest wifi while phone was on family wifi…
                            • N Offline
                              Nneuland @sdetweil
                              Nailed it! That was exactly the issue.
                              Thank you Sam. SOLVED
                              C D 2 Replies Last reply Reply Quote 1
                                CheapDad @Nneuland
                                :grinning_face_with_sweat:
                                  DigiDadbod @Nneuland
                                  @nneuland just want to let you know; depending on how good your router is, you should be able to get it set up on a separate IOT network if desired. I forget exactly how I set mine up but it was either by allowing specific IP addresses to talk to each other one way, or a combo of that and enebling mDNS of some sorts (which is something I think you have to enable for things like Google speaker on an adjacent local network). Obviously, you will find better info on a forum dedicated to your router…
                                  • N Offline
                                    Nneuland @DigiDadbod
                                    @digidadbod
                                    That’s great. Thank you for the tip
