MMM- Remote Control help
Can anyone explain the ip modifications needed to the config file for the Remote Control module?
@nneuland the address and ipWhilelist fields control what clients can connect to MagicMirror
address set to “localhost”, means only apps INSIDE the same machine can connect
changing to “0.0.0.0” (all adapters) means SOME systems outside the MM machine can connect,
and ipWhitelist give a list of address masks to test if those systems are allowedfor easy access , and no security for anyone on your local lan/wifi), address:“0.0.0.0” and ipWhiltelist:[] will allow anyone on your lan/wifi to connect to the MagicMirror application
Thank you for the reply. After adjusting the address to “0.0.0.0” and adding my IP, I’m in a holding pattern of blank screen and curser, and no connection to the http://192.168.xxx.xxx:8080/remote.html website.“This site can’t be reached”
@nneuland did u remove everything from ipWhitelist?
This is what have in my ipWhitelist
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “ffff:192.168.XXX.XXX”], // Set [] to allow all IP addresses
I have xxx’d my actual ip address.
@nneuland 1st let’s take everything out
Thanks for the help. []
This site can’t be reached192.168.xxx.xxx took too long to respond.
Try:Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT -
@nneuland can u connect to mm
@nneuland sadly no
This site can’t be reachedCheck if there is a typo in ip.
If spelling is correct, try running Windows Network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN -
@nneuland ok, so it’s a networking problem
u said windows… I always turn off the firewall for a while
