    Saving file causing MM to reload
    4 Posts 2 Posters 791 Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      When I save the config file the MM reloads in fullscreen mode and my past MM builds did not do this.
      How do I stop this? I like to save my work periodically and having to go through the toggle fullscreen every time I click save is annoying.
        sdetweil @ankonaskiff17
        @ankonaskiff17 are you using PM2. It does that if you used my script to install
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          ankonaskiff17 @sdetweil
          @sdetweil I did use your script.
            @ankonaskiff17 and said yes to use pm2?
