    Multiple instances
    12 Posts 3 Posters 5.2k Views 3 Watching
    • E Offline
      ELMAGO
      Good morning all
      can we run two maggic mirror instances with different modules on the same RPI? with of course a different port.
      thank you
        sdetweil @ELMAGO
        @elmago sure, I do this on my pi4 on different displays sometimes.
        install one, copy the mm folder tree to another name, MagicMirror2 and change the port and modules used…
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          ELMAGO @sdetweil
          surely you have to rewrite the mm.sh file too?
          thank you
            sdetweil @ELMAGO
            @elmago yes that too…
            E 2 Replies Last reply Reply Quote 0
            • E Offline
              ELMAGO @sdetweil
              @sdetweil super thank you
              • E Offline
                ELMAGO @sdetweil
                Hello,
                I tried your solution, in absolute terms it works.
                Except that I did not think of a particularity.
                Indeed, I have a screen connected to the RPI which broadcasts the “basic” port 8080 maggic mirror.
                If I apply your policy, the screen will show me the port 8085 or 8080 instance every other time.
                How do I force this screen to open the port 8080 instance?
                Thanks in advance.
                  sdetweil @ELMAGO
                  @elmago eh??
                  only ONE can be on screen at a time…
                  on my pi 4 I have 2 screens, 1 on each HDMI port, with a separate MM instance on each
                  which ever is started last will be on the single physical screen
                  • E Offline
                    ELMAGO @sdetweil
                    Hello.
                    I must have expressed myself badly.
                    yes indeed there is only one on the screen but when I restart the RPI it displays one or the other.
                    if I understand your explanation correctly, I have to put in the file mm.sh last the instance that I want to display on the physical screen.
                    thank you
                    TipponT 1 Reply Last reply Reply Quote 0
                    • TipponT Offline
                      Tippon @ELMAGO
                      @elmago What is it that you want to do exactly?
                      As @sdetweil says, only one instance can be on the screen at a time. Are you trying to run one on the screen and access another one remotely? If you are, this may help.
                      I’ve got two instances running, and they have different modules and a different port. The ‘standard’ MM instance uses the mm.sh that’s generated from @sdetweil’s script:
                      cd ./MagicMirror
                      DISPLAY=:0 npm start
                      while my second instance runs as a server, and doesn’t display on the Pi’s screen. My second instance is in the MagicMirror2 folder and uses this script:
                      cd ./MagicMirror2
                      DISPLAY=:0 npm run server
                      I use a separate .sh script, but someone more knowledgeable could probably combine them. The first section of the config.js lets you define which port you want MM to use, so I changed it on the one I wanted to view remotely.
                      var config =
                        address: '0.0.0.0',
                        port: 12345,
                        ipWhitelist: [
                          '127.0.0.1',
                          '::ffff:127.0.0.1',
                          '::1',
                          '::ffff:192.168.0.1/120',
                          '192.168.0.1/24'
                      Please forgive me if I'm slow to reply, I'm currently experiencing memory issues, and sometimes forget that I've asked a question >.<
                      • E Offline
                        ELMAGO @Tippon
                        @tippon
                        Hello
                        I did like you and it works perfectly.
                        Thank you so much.
                        S TipponT 2 Replies Last reply Reply Quote 2
                          sdetweil @ELMAGO
                          @elmago you never said u wanted one as a server!..
                          • TipponT Offline
                            Tippon @ELMAGO
                            @elmago said in Multiple instances:
                            @tippon
                            Hello
                            Thank you so much.
                            No problem, glad I could help :)
                            • C cweinhofer referenced this topic on
