    Keeps crashing
    3 Posts 3 Posters 771 Views 3 Watching
      bradley1982
      Hi there, total newbie at code and all this and was a lock down project.
      Got a pi zero and set up and all working however after a couple of days it keeps crashing and either goes back to the ‘something wrong internet page’ or goes back to the desktop with no icons and I need to unplug and plug in and run the commands and works again for the next couple of days.
      Any ideas what might be causing this?
      All help gratefully received!!
      Many thanks
      Paul
      S R 2 Replies Last reply Reply Quote 0
        sdetweil @bradley1982
        @bradley1982 how did u install MagicMirror?
        I have a pi 0 that runs and runs
          rico24 Module Developer @bradley1982
          @bradley1982 Did use pm2 for example ? Then you could try to use the command: “pm2 logs ” (most of the times mm.sh) to check the logs.
          Could you try to share those logs so we can take a look?
