    • Search
    adding new modules the old one doesn't work
    Troubleshooting
    • R
      rebecca last edited by
      Hi there!
      I would like to ask about the problem that I often experience when installing new modules. why when I installing a new module, the old module that has been installed does not work ? it really confused me
        sdetweil @rebecca last edited by sdetweil
        @rebecca please explain more… an example would help
        • R
          rebecca @sdetweil last edited by
          @sdetweil so when I installing the new magic mirror modules (e. mmm-widget) my old modules (e. mmm-spotify) doesn’t work. so i try to uninstall the new modules hoping the old one still work but it doesn’t work at all. can someone tell me how to fix it ? so that when I installing a new module, the other modules still work.
            @rebecca never had that problem.
            can u look at the console where u start mm,
            either by using npm start or pm2.
            if pm2, then the pm2 logs --lines=100 would show the info.
            also open the developers window, ctrl-shift-i on the mirror keyboard, and select the tab labeled console and scroll up to see any errors usually red text
            • R
              There is no any errors when i run dev mode
                @rebecca need the tab labeled console
                you are showing the elements tab
