    Error in using python with child_process
    3 Posts 2 Posters 274 Views 2 Watching
      doridol
      node_helper.js
      const spawn = require('child_process').spawn;
      const NodeHelper = require("node_helper");
      var self;
          start: function () {
              self = this;
              console.log("Starting node_helper for: " + this.name);
          getData: function () {
              const result = spawn('python', ['/home/pi/MagicMirror/modules/MMM-DustInfo/Naver_geo.py']);
      		result.stdout.on('data', function(data) {
      			console.log(data.toString());
      			recivedData = data.toString();
      			recivedData = JSON.parse(recivedData);
      		  result.on('close', (code) => {
      			console.log(recivedData.station);
      			station = recivedData.station;
      			pm10 = recivedData.pm10;
      			var recivedData = {
                      station,
                      pm10
      			self.sendSocketNotification('TEXT_RESULT', recivedData);
      		  process.on('exit', function() {
      			if (x) {
      			  x.kill();
          socketNotificationReceived: function (notification, payload) {
              if (notification === 'GET_TEXT_DATA') {
                  self.getData();
      my python file code
      import requests
      import pandas as pd
      import json
      import urllib.request
      from bs4 import BeautifulSoup
      from haversine import haversine
      station_data = pd.read_excel("/home/pi/Desktop/Dust/station_list.xlsx")
      location_data = pd.read_excel("/home/pi/Desktop/Dust/location.xlsx")
      location_data = location_data.values.tolist()
      def search_map(search_text):
          client_id = 'vo9k89s848' #클라이언트 ID값
          client_secret = 'MPooQfaCMH9eSMnT50RvNEYjChshVRHwq3qiBoQi' #클라이언트 Secret값
          encText = urllib.parse.quote(search_text)
          url = 'https://naveropenapi.apigw.ntruss.com/map-geocode/v2/geocode?query='+encText
          request = urllib.request.Request(url)
          request.add_header('X-NCP-APIGW-API-KEY-ID', client_id)
          request.add_header('X-NCP-APIGW-API-KEY', client_secret)
          response = urllib.request.urlopen(request)
          rescode = response.getcode()
          if(rescode==200):
              response_body = response.read()
              return response_body.decode('utf-8')
      def station_info():
          station_info = []
          for i in range(489):
              info = search_map(station_data.loc[i]['측정소 주소'])
              info = json.loads(info)
              station_info.append([float(info['addresses'][0]['y']),float(info['addresses'][0]['x'])])
          return station_info
      def curr_LocInfo():
          curr_LocInfo = []
          info = search_map("서울특별시 노원구 공릉로 232")
          curr_LocInfo.append([float(info['addresses'][0]['y']),float(info['addresses'][0]['x'])])
          return curr_LocInfo
      def Loc_to_xlsx():
          station_x = station_info()
          station_x = pd.DataFrame(station_x)
          station_x.to_excel("C:/Users/sks12/Desktop/PythonWorkspace/Dust_Window/location.xlsx")
      def search_station():
          station_Loc = location_data
          curr_Loc = curr_LocInfo()
          min = 10000
              distance = haversine((station_Loc[i][1], station_Loc[i][2]), curr_Loc[0], unit = 'km')
              if distance < min:
                  min = distance
                  globals()['station_index'] = i
      def Dust_info():
          search_station()
          city = station_data.loc[station_index]['측정소명']
          key = "mr81qR0Ed0RG4%2FUFpmXXLO0c7AO3HI6PC%2BVFgy%2BMO1yZ%2F7ciBAJejaPZ%2FmHi%2F30D4CYg7DKkGwpxHXTgHQDTSQ%3D%3D"
          url = "http://apis.data.go.kr/B552584/ArpltnInforInqireSvc/getMsrstnAcctoRltmMesureDnsty?stationName={}&dataTerm=month&pageNo=1&numOfRows=100&returnType=xml&serviceKey={}".format(city, key)
          res = requests.get(url)
          res.raise_for_status()
          content = BeautifulSoup(res.text, "lxml")
          dust = content.item
          pm10 = dust.pm10value
          check = pm10.get_text()
          if check == '-':
              dust = dust.next_sibling
          pm10 = int(pm10.get_text())
          # print("near station: {}".format(station_data.loc[station_index]['측정소명']))
          # print("dust info:{}".format(pm10))
          data = {
              "station" : station_data.loc[station_index]['측정소명'],
              "pm10" : pm10
          data_json = json.dumps(data)
          print (data_json)
      Dust_info()
      my module code
      Module.register("MMM-DustInfo", {
      	defaults: {
      		updateInterval: 60000,
      	requiresVersion: "2.1.0", // Required version of MagicMirror
              // Log.info("Starting module: " + this.name);
              // requiresVersion: "2.1.0";
              // this.loaded = false;
              this.scheduleUpdate();
          getStyles: function() {
              return["MMM-DustInfo.css"];
      	scheduleUpdate: function () {
              setInterval(() => {
                  this.getData();
              }, this.config.updateInterval);
              this.getData();
      	getData: function() {
      		console.log('GET_TEXT_DATA', this.config)
      		this.sendSocketNotification('GET_TEXT_DATA', this.config);
      		if (notification === "TEXT_RESULT") {
      			this.textDataRecived = payload;
      			this.loaded = true;
      	   this.updateDom();
      	getDom: function () {
              if (!this.loaded) {
                  wrapper.innerHTML = "LOADING";
                  return wrapper;
              if (this.loaded) {
                  var table = document.createElement('td');
                  var space1 = document.createElement('tr');
                  var space2 = document.createElement('tr');
                  var pm10Icon = document.createElement("tr");
                  if (this.textDataRecived.pm10 <= 30) {
                      Icon_pm10 = "fa fa-smile-o";
                      pm10Icon.id = 'smile'
                  else if (this.textDataRecived.pm10 > 30 && this.textDataRecived.pm10 <= 80) {
                      Icon_pm10 = "fa fa-meh-o"
                      pm10Icon.id = 'meh'
                  else {
                      Icon_pm10 = "fa fa-frown-o"
                      pm10Icon.id = 'frown'
                  pm10Icon.className = Icon_pm10;
                  var pm10Data = document.createElement('span');
                  pm10Data.className = "medium";
                  pm10Data.innerHTML = "PM10: " + this.textDataRecived.pm10 +" ppm";
                  var stationIcon = document.createElement("tr");
                  stationIcon.className = "fa fa-home";
                  var stationData = document.createElement("span");
                  stationData.className = "medium";
                  stationData.innerHTML = "내 위치: " + this.textDataRecived.station;
                  table.appendChild(space1);
                  table.appendChild(space2);
                  space1.appendChild(pm10Icon);
                  pm10Icon.appendChild(pm10Data);
                  space2.appendChild(stationIcon);
                  stationIcon.appendChild(stationData);
                  wrapper.appendChild(table);
              return wrapper;
      and i got a error like this
      [01.07.2021 23:12.25.107] [LOG]   {"station": "\ub178\uc6d0\uad6c", "pm10": 31}
      [01.07.2021 23:12.25.342] [ERROR] Whoops! There was an uncaught exception...
      [01.07.2021 23:12.25.345] [ERROR] TypeError: Cannot read property 'station' of undefined
          at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-DustInfo/node_helper.js:23:28)
          at ChildProcess.emit (events.js:315:20)
          at maybeClose (internal/child_process.js:1021:16)
          at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
      I want to display pm10 value and nearest dustinfo station using airkorea API
      I’m really beginner please help me…
        sdetweil @doridol
        @doridol
        In node_helper
        receiveddata needs to be defined outside the on handlers. u could move the handling up to the on data, and remove the on close
          doridol @sdetweil
          @sdetweil Really really thanks!! I solved problem
