    MMM-Face-Reco-DNN + ProfileSwitcher
    21 Posts 3 Posters 7.4k Views 3 Watching
      Stardyze
      Has anyone had any luck trying to use the two modules together? I have tried editing the .js in the Face-Reco module to fit with the other one like said in the documentation of the ProfileSwitcher module but since it is a different module not all things line up.
        sdetweil @Stardyze
        @stardyze they are both doing the same thing, switching to different profiles… so that seems troublesome
          Stardyze @sdetweil
          @sdetweil Sorry I’m new where in the Face-Reco can you set profiles instead of using MMM-ProfileSwitcher? Can you have different layouts for different people using just the MMM-Face-Reco-DNN module?
            sdetweil @Stardyze
            @stardyze yes, facereco uses the ‘classes’ field of the module to organize module display by ‘person’
            u set modules for me (sam) by adding a classname ‘sam’
            u can have multiple people share the same one, classes:‘sam bob sue’
              Stardyze @sdetweil
              This post is deleted!
                Stardyze @sdetweil
                @sdetweil I have all the modules selected with the class name I want for them do I set the class name in the config.js or MMM-Face-Reco-DNN.js?
                  sdetweil @Stardyze
                  @stardyze in config.js, on each module set the classes per person
                  module: “clock:,
                  classes:” fred sue",
                  same for every module
                  u have to set allowed users in facreco of course
                    Stardyze @sdetweil
                    @sdetweil Yeah I set all the classes for each module in the config.js but for so that it knows the allowed users is that in the MMM-Face-Reco-DNN.js? Like the first declaration of the classname.
                      sdetweil @Stardyze
                      @stardyze there is no ‘actual’ class… Facereco just looks at the classes field to match against user names
                        Stardyze @sdetweil
                        @sdetweil So I can’t have specific classes or layouts for each person?
                          sdetweil @Stardyze
                          @stardyze https://github.com/nischi/MMM-Face-Reco-DNN
                          Yes, and you can share…
                          layout is a challenge… like profile u need multiple instances of the same module,
                          for different users…
                          MM can only show or hide modules… so, you have one instance for sam, and another for bob
                            Stardyze @sdetweil
                            @sdetweil I do have classes set in each module but it doesn’t switch the profiles when a face is recognized. In the terminal, it says that the right user is recognized and is logged in but the layout doesn’t change.
                              sdetweil @Stardyze
                              @stardyze see
                              https://github.com/nischi/MMM-Face-Reco-DNN#classes
                              case of the names matters… Sam does not equal sam
                                Stardyze @sdetweil
                                @sdetweil I did look through that page and all the case names are the same (lowercase) from my dataset folders for each person to the class names for each module and it still doesn’t switch modules in the mirror. Do I have to classify the each class first in the .js in the facereco module first?
                                  sdetweil @Stardyze
                                  @stardyze u now know everything I know…
                                  I set the module up once, and it worked on the 1st try. haven’t used it since (as I am the only user)
                                    Stardyze @sdetweil
                                    @sdetweil Okay haha thank you so much for your time
                                      sdetweil @Stardyze
                                      @stardyze the mosdule classes are space separated… right?
                                        Stardyze @sdetweil
                                        @sdetweil you mean like the name of the class is not right next to the colon?
                                          sdetweil @Stardyze
                                          @stardyze no
                                          classes: “sam bob sue fred”
                                          not
                                          classes: “sam, bob, sue, fred”
                                            Stardyze @sdetweil
                                            @sdetweil Oh yeah of course for each module I have a space like “sam bob sue fred”
