    MMM-Face-Reco-DNN + ProfileSwitcher
    21 Posts 3 Posters 7.7k Views 3 Watching
      sdetweil @Stardyze
      @stardyze https://github.com/nischi/MMM-Face-Reco-DNN
      Yes, and you can share…
      layout is a challenge… like profile u need multiple instances of the same module,
      for different users…
      MM can only show or hide modules… so, you have one instance for sam, and another for bob
        Stardyze @sdetweil
        @sdetweil I do have classes set in each module but it doesn’t switch the profiles when a face is recognized. In the terminal, it says that the right user is recognized and is logged in but the layout doesn’t change.
          sdetweil @Stardyze
          @stardyze see
          https://github.com/nischi/MMM-Face-Reco-DNN#classes
          case of the names matters… Sam does not equal sam
            Stardyze @sdetweil
            @sdetweil I did look through that page and all the case names are the same (lowercase) from my dataset folders for each person to the class names for each module and it still doesn’t switch modules in the mirror. Do I have to classify the each class first in the .js in the facereco module first?
              sdetweil @Stardyze
              @stardyze u now know everything I know…
              I set the module up once, and it worked on the 1st try. haven’t used it since (as I am the only user)
                Stardyze @sdetweil
                @sdetweil Okay haha thank you so much for your time
                  sdetweil @Stardyze
                  @stardyze the mosdule classes are space separated… right?
                    Stardyze @sdetweil
                    @sdetweil you mean like the name of the class is not right next to the colon?
                      sdetweil @Stardyze
                      @stardyze no
                      classes: “sam bob sue fred”
                      not
                      classes: “sam, bob, sue, fred”
                        Stardyze @sdetweil
                        @sdetweil Oh yeah of course for each module I have a space like “sam bob sue fred”
                        • N Offline
                          njw
                          A “soft-announce” for something I’m working on, but is almost ready to be released…
                          I’ve had problems with all the versions of face-recognition, profile-switching, debugging… so I’m attempting to create a new module that takes out most of the pain. The pain of getting the profiles configured correctly is still there (that’s job#2), but the facial recognition… that was something I wanted to try and improve. So, pre-announcing a new face recognition module (because we all need another module doing the same thing).
                          https://github.com/njwilliams/MMM-Faces
                          I welcome thoughts/suggestions to improve this!
